Failed to resolve DNS records behind router..
onpage3cisco
I have created a network topology by using GNS3, I have created a DNS server behind router 3600.
All other work stations are also behind diffrent routers, with diffrent external addresses.
No issues to ping external ip address of the DNS router from any where in the network, I'm pinging from the work stations and setup the correct DNS IP address.
The DNS server is well setup, no issues with nslookup. The router has internal network address.
The problem , I think I'm missing something in my router configuration (NAT, Port forwarding..) None of the worstations is doing resolve to
the dns records on the DNS server.
Any ideas ?
Thanks In Advanced.
John Blakley
It's going to be hard to tell you without seeing the config, but generally speaking it's usually a case of having an acl on the wan interface that doesn't allow the request back in. First thing I would do is remove anything security related off of the interface and see if it works before putting on acls, cbac, etc. Otherwise, post your config and we can help you further...
HTH,
John
HTH, John *** Please rate all useful posts ***
Thanks for the quick reply.
I have attached my config router settings behind the DNS server (10.10.2.10)
version 12.4
hostname COLO_2
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$wPYg$AyyigqiQptspKno6pqKvC0
no aaa new-model
memory-size iomem 5
ip cef
ip host CORE 172.16.0.2
ip host COLO_1 172.16.1.2
ip host COLO_2 172.16.2.2
ip host ISP 172.16.0.1
interface Tunnel0
description = GRE Tunnel To CORE =
ip address 192.168.200.2 255.255.255.0
tunnel source 172.16.2.2
tunnel destination 172.16.0.2
interface Serial0/0
ip address 172.16.2.2 255.255.255.252
serial restart-delay 0
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface Ethernet1/0
description = To COLO_2 LAN =
ip address 10.10.2.1 255.255.255.0
half-duplex
interface Ethernet1/1
no ip address
shutdown
half-duplex
interface Ethernet1/2
no ip address
shutdown
half-duplex
interface Ethernet1/3
no ip address
shutdown
half-duplex
router eigrp 100
network 10.0.0.0
network 192.168.200.0
no auto-summary
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.2.1
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
