IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/1: the fragment table has reached its maximum threshold 16
j_friedrich
                   Hi guys,
     I have tried to change it to max-reassemblies in ios 15, but, no luck.  It still shows the ip -virtual-reassembly in.  Checked the interface and still at 16.  Obviously, I have the syntax wrong to change it...
Ideas?
Thanks for your time.
johnlloyd_13
Level 9
Level 9
Why not remove it unless there's a specific need for the said command line?
paolo bevilacqua
As Johonny suggested, remove the command that is know to cause a lot of trouble.
It was simply a bad idea by Cisco to make it a default.
Hi guys,
     So, to futher my comprehension of this, why is it needed?  Where would you use it?  I have a 2821 box used as a l2tp box and have this feature setup in virtual-ppp1 interface also...Why, needed?  or just a default.
THANKS for your time and input!
Jason
It is needed in case some complex ACL rule or IPS needs to look at the entire packet. Otherwise thing works perefectly without.
Please remember to rate useful posts clicking on the stars below.
