Showing results forĀ
Search instead forĀ
Did you mean:Ā
Increase Metric Received EIGRP
ricardorojas123
I have two Cisco Router in the border of the network. And the main Router of the ISP is connected to the RouterA, and the backup ISP Router is connected whit the second Router, called RouterB. Both Router is running EIGRP whit the same  AS 100. The question is How I can increase the value of the routes received from the RouterB.
(ISP 1) --- > RouterA , Default Metric EIGRP 90
(ISP 2) --- > RouterB , Modified Metric EIGRP 120
But I can change the Administrative Distances of EIGRP ? 90
AD and metric are 2 different things.
AD is only used to choose a route with same metric advertised by 2 different sources.
Regards.
Alain.
