07-24-2013 02:47 PM - edited 03-04-2019 08:32 PM
Hello Support Community,
I am seeing incrementing "overrun" type of input errors on a FastEthernet interface on a Cisco 3845 series router. I am well aware of the fact that overrun errors MAY BE caused due to "input rate exceeding the rate at which the interface receiver hardware can write the packets to the hardware buffer" as per Cisco documentation. However, the input rate on this interface averages at around 1.5 Mbps and the output rate averages at around 500 kbps. Here's what the interface statistics look like from a monitoring perspective.
| Receive | Transmit | |||
| Interface Bandwidth | 100.0 Mbps | 100.0 Mbps | ||
| Current Traffic | 1.503 Mbps | 412.542 kbps | ||
| Percent Utilization | 2 % | 0 % | ||
| Packets per Second | 849.0 pps | 512.0 pps | ||
| Average Packet Size | 221 bytes | 101 bytes |
The network topology is as follows:
[3845 router [Fa3/0]]------------[[Gi5/2] CAT4500 switch]
Speed and duplex on both sides of the link are set to 100 and full respectively. There are no errors on the CAT 4500 switch side of the link. I increased the hold-queue input size on the 3845 router side interface from the default 75 to 2048 in an effort to see if it stops the incrementing errors but it did not.
I am also seeing the total output drop counter rising gradually. The input errors counter rises much much faster than the output drop counter though.
sh int fa3/0
FastEthernet3/0 is up, line protocol is up
Hardware is AmdFE, address is 0013.7f72.6001 (bia 0013.7f72.6001)
Description: Int-to-Customer Network
Internet address is 10.0.1.251/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 254/255, txload 1/255, rxload 6/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:23:54
Input queue: 0/2048/0/0 (size/max/drops/flushes); Total output drops: 259
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2424000 bits/sec, 906 packets/sec
5 minute output rate 450000 bits/sec, 535 packets/sec
4890108 packets input, 1761777920 bytes
Received 7578 broadcasts, 0 runts, 0 giants, 0 throttles
54709 input errors, 0 CRC, 0 frame, 54709 overrun, 0 ignored
0 watchdog
2920904 packets output, 313102254 bytes, 0 underruns
0 lost carrier, 0 no carrier
sh int fa3/0 accounting
FastEthernet3/0 Int-to-Customer Network
Protocol Pkts In Chars In Pkts Out Chars Out
Other 374 19822 1129 67740
IP 11394712 76208123 6874875 730544863
DEC MOP 0 0 20 1540
ARP 4962 297720 7 420
sh int fa3/0 switching
Throttle count 0
Drops RP 18 SP 0
SPD Flushes Fast 66 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 56666977 Drops 0
Protocol IP
Switching path Pkts In Chars In Pkts Out Chars Out
Process 754269402 562447667 1038407414 1891734184
Cache misses 48 - - -
Fast 985631026 3406265085 3728614892 2275699977
Auton/SSE 0 0 0 0
Protocol DEC MOP
Process 0 0 69246 5331942
Cache misses 0 - - -
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 13539896 812393760 23224 1393440
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 1387770 73551810 4163782 249826920
Fast 0 0 0 0
Auton/SSE 0 0 0 0
NOTE: all counts are cumulative and reset only after a reload.
Can anyone predict what may be causing these high number input errors and point me in the right direction? I can provide more information on the interface statistics and any other router related configuration if required.
Thanks.
07-24-2013 03:50 PM
reliability 254/255
I think you got a cable issue. This value should ALWAYS bee 255/255 and should never go down.
07-24-2013 04:18 PM
You have a point there regarding the cable and I will definitely look into replacing it, but....
Isn't Reliability value dropping an effect of the high number input errors and not a cause?
Reliability = total errors / total frames.
I got the below from a cisco support forum post -
"Reliability is generally used to identify whether we successfully transmit or receive a packet and it is expressed as a fraction of 255. It is calculated by summing all the packets received and transmitted and dividing that number into the sum of all input and ouput errors and expressing that as a fraction of 255. It is then exponentially weighted over five minutes so that the most current reading has greater weight than the first reading. Basic definition of reliability is errors/total frames. If your interface reads 255/255, then it means all is well."
Thanks.
07-24-2013 04:28 PM
Here's an output of show controller for that particular interface, do you think it indicates an issue with the cable itself?
show controller fa3/0
Interface FastEthernet3/0
Hardware is AMD Am79c971
ADDR: C00B0968, FASTSEND: 6023D370, MCI_INDEX: 0
DIST ROUTE ENABLED: 0
Route Cache Flag: 613
LADRF=0x0000 0x0100 0x2001 0x0002
CSR0 =0x00000072, CSR3 =0x00001044, CSR4 =0x00004B1D, CSR15 =0x00008180
CSR80 =0x00009900, CSR114=0x00000000, CRDA =0x2E0C36E0, CXDA =0x2E0C3E10
BCR9 =0x00000001 (full-duplex)
CSR5 =0x00000001, CSR7 =0x00000820, CSR100=0x0000F000, CSR125=0x00005C3C
BCR2 =0x00000000, BCR9 =0x00000001, BCR18 =0x000019E0, BCR22 =0x0000FF06
BCR25 =0x000000FF, BCR26 =0x00000080, BCR27 =0x00000010, BCR32 =0x00004480
HW filtering information:
Promiscuous Mode Enabled, PHY Addr Enabled, Broadcast Addr Enabled
PHY Addr=0013.7F72.6001, Multicast Filter=0x0000 0x0100 0x2001 0x0002
amdp2_instance=0x70285F70, registers=0x4C100000, ib=0x2D75B9C0
rx ring entries=64, tx ring entries=128
rxring=0x2E0C3540, rxr shadow=0x66CA4F50, rx_head=26, rx_tail=0
txring=0x2E0C3980, txr shadow=0xC00B1760, tx_head=73, tx_tail=73, tx_count=0
Software MAC address filter(hash:length/addr/mask/hits):
0x00: 0 ffff.ffff.ffff 0000.0000.0000 13524414
0x0F: 0 0000.0c07.ac03 0000.0000.0000 1313180569
0x5C: 0 0100.5e00.0002 0000.0000.0000 43124342
0x7E: 0 0013.7f72.6001 0000.0000.0000 389537278
0xC0: 0 0180.c200.0002 0000.0000.0000 0
0xC0: 1 0100.0ccc.cccc 0000.0000.0000 1387845
0xC5: 0 0180.c200.0007 0000.0000.0000 0
spurious_idon=0, filtered_pak=31187921, throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=0
rx_bpe_err=0, rx_soft_overflow_err=0, rx_no_enp=0, rx_discard=0
tx_one_col_err=0, tx_more_col_err=0, tx_no_enp=0, tx_deferred_err=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
hsrp_conf=1, need_af_check=1
tx_limited=0(64)
PHY registers:
Register 0x00: 2100 780D 7810 0003 0101 0000 0000 0000
Register 0x08: 0000 0000 0000 0000 0000 0000 0000 0000
Register 0x10: 0000 0000 4000 0000 38C8 0010 0000 0002
Register 0x18: 0001 0000 0000 0000 0000
Thanks.
04-29-2016 06:42 AM
I am having the same problem with a number of 2901 routers. Did you manage to resolve the issue in the end? Any solutions please suggest.
07-24-2013 04:34 PM
No. Reliability is saying "How reliable is my layer 1".
Change the entire length of the cable OR run a full TDR test.
08-26-2013 07:29 PM
Replaced the cable and still see the incrementing errors.
08-26-2013 07:39 PM
Post the same commands as before, plus include "sh counter interface Fast 3/0".
08-29-2013 11:59 AM
sh int Fa3/0
Internet address is x.x.x.x/24
reliability 253/255, txload 2/255, rxload 18/255
Last clearing of "show interface" counters 06:54:37
Input queue: 0/2048/0/0 (size/max/drops/flushes); Total output drops: 1534
30 second input rate 7211000 bits/sec, 1435 packets/sec
30 second output rate 821000 bits/sec, 889 packets/sec
31915418 packets input, 2934180951 bytes
Received 37501 broadcasts, 0 runts, 0 giants, 0 throttles
222060 input errors, 0 CRC, 0 frame, 222060 overrun, 0 ignored
0 watchdog
21232362 packets output, 2579907005 bytes, 0 underruns
sh controller fa3/0
CSR80 =0x00009900, CSR114=0x00000000, CRDA =0x2E0C3570, CXDA =0x2E0C3BE0
rxring=0x2E0C3540, rxr shadow=0x66CA4F50, rx_head=3, rx_tail=0
txring=0x2E0C3980, txr shadow=0xC00B1760, tx_head=38, tx_tail=38, tx_count=0
0x00: 0 ffff.ffff.ffff 0000.0000.0000 277131
0x0F: 0 0000.0c07.ac03 0000.0000.0000 838686427
0x5C: 0 0100.5e00.0002 0000.0000.0000 681009
0x7E: 0 0013.7f72.6001 0000.0000.0000 10086656
0xC0: 1 0100.0ccc.cccc 0000.0000.0000 21918
spurious_idon=0, filtered_pak=33483715, throttled=0, enabled=0, disabled=0
tx_underrun_err=1, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_limited=0(64)
PHY registers:
Other 302 16006 907 54420
IP 8997487 2398365672 6249085 949233080
DEC MOP 0 0 15 1155
ARP 3981 238860 1 60
Throttle count 0
Drops RP 123 SP 0
SPD Flushes Fast 74 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 61174368 Drops 0
Protocol IP
Process 827218827 2329207405 1136910030 2216013801
Fast 508035336 28232545 1619944066 3467603049
Auton/SSE 0 0 0 0
Protocol DEC MOP
Process 0 0 74403 5729031
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 14838705 890322300 24881 1492860
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 1491007 79023371 4473800 268428000
Fast 0 0 0 0
Auton/SSE 0 0 0 0
sh int fa3/0 stats
FastEthernet3/0
Processor 302885 25285101 411720 55758990
Route cache 9293267 2909400397 6183285 924543723
Total 9596152 2934685498 6595005 980302713
sh int fa3/0 summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* FastEthernet3/0 0 0 0 136 7578000 1438 739000 867 0
08-29-2013 07:13 PM
reliability 253/255, txload 2/255, rxload 18/255Nope. Still faulty cable.
09-05-2013 10:24 AM
Ok, I failed over to the secondary router and made it the primary now. Replaced the cable 3 times. Moved the other end of the cable from the CAT 4500 switch number 1 to CAT 4500 switch number 2 on a different blade. Changed both ends of the connection (CAT and router) speed and duplex to auto / auto. There are no errors on the CAT switch end. The IOS on the routers is 12.4(15)T1.
Still see the same input errors. As you said though the reliabilty is 255/255 now.
sh int fa3/0
Hardware is AmdFE, address is x.x.x (bia x:x:x)
reliability 255/255, txload 1/255, rxload 15/255
Last clearing of "show interface" counters 12:16:43
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 446
5 minute input rate 6215000 bits/sec, 1163 packets/sec
5 minute output rate 647000 bits/sec, 759 packets/sec
64960035 packets input, 302868023 bytes
Received 65287 broadcasts, 0 runts, 0 giants, 0 throttles
20316 input errors, 0 CRC, 0 frame, 20316 overrun, 0 ignored
0 watchdog
40228479 packets output, 4289802996 bytes, 0 underruns
sh controller fa3/0
ADDR: 66F34824, FASTSEND: 6023D370, MCI_INDEX: 0
CSR80 =0x00009900, CSR114=0x00000000, CRDA =0x2E0C3740, CXDA =0x2E0C3D50
BCR9 =0x00000001
PHY Addr=001D.7038.6421, Multicast Filter=0x0000 0x0100 0x2001 0x0002
amdp2_instance=0x66F358CC, registers=0x4C100000, ib=0x2D75B9C0
rxring=0x2E0C3540, rxr shadow=0x66F35EB8, rx_head=32, rx_tail=0
txring=0x2E0C3980, txr shadow=0x66F35FEC, tx_head=61, tx_tail=61, tx_count=0
0x00: 0 ffff.ffff.ffff 0000.0000.0000 18312
0x0F: 0 0000.0c07.ac03 0000.0000.0000 65147725
0x51: 0 001d.7038.6421 0000.0000.0000 459815
0x5C: 0 0100.5e00.0002 0000.0000.0000 46458
0xC0: 1 0100.0ccc.cccc 0000.0000.0000 1494
spurious_idon=0, filtered_pak=35497, throttled=0, enabled=0, disabled=0
tx_limited=0(64)
PHY registers:
Register 0x00: 1000 782D 7810 0003 01E1 CDE1 000B 0000
09-05-2013 10:54 AM
I am also investigating buffer issues because I am seeing a lot of misses. Here's the output.
show buffers
Buffer elements:
1115 in free list (1119 max allowed)
60723871 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 148, permanent 50, peak 240 @ 07:14:29):
112 in free list (20 min, 150 max allowed)
43720721 hits, 11417 misses, 4403 trims, 4501 created
4638 failures (0 no memory)
Middle buffers, 600 bytes (total 27, permanent 25, peak 97 @ 2w0d):
25 in free list (10 min, 150 max allowed)
22696413 hits, 4115 misses, 2035 trims, 2037 created
3099 failures (0 no memory)
Big buffers, 1536 bytes (total 53, permanent 50, peak 53 @ 2w0d):
52 in free list (5 min, 150 max allowed)
20854107 hits, 2970 misses, 1235 trims, 1238 created
2462 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 4, permanent 10, peak 203 @ 1d22h):
3 in free list (0 min, 100 max allowed)
43437529 hits, 2446 misses, 744 trims, 738 created
2094 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 3 @ 1w1d):
1 in free list (0 min, 10 max allowed)
42 hits, 2052 misses, 150 trims, 151 created
2052 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 3 @ 1w1d):
1 in free list (0 min, 4 max allowed)
42 hits, 2010 misses, 150 trims, 151 created
2010 failures (0 no memory)
Interface buffer pools:
Syslog ED Pool buffers, 600 bytes (total 150, permanent 150):
118 in free list (150 min, 150 max allowed)
39086 hits, 0 misses
CD2430 I/O buffers, 1536 bytes (total 0, permanent 0):
0 in free list (0 min, 0 max allowed)
0 hits, 0 fallbacks
IPC buffers, 4096 bytes (total 2, permanent 2):
2 in free list (1 min, 8 max allowed)
0 hits, 0 fallbacks, 0 trims, 0 created
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
256 in free list (128 min, 1024 max allowed)
512 hits, 0 misses, 0 trims, 0 created
512 max cache size, 512 in cache
63835 hits in cache, 0 misses in cache
Particle Clones:
1024 clones, 4 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 768, permanent 768):
4 hits in cache, 0 misses in cache
CRYPTO_HW buffers, 1548 bytes (total 1536, permanent 1536):
0 in free list (0 min, 1536 max allowed)
1536 hits, 0 misses
1536 max cache size, 1024 in cache
512 hits in cache, 0 misses in cache
Normal buffers, 1676 bytes (total 3840, permanent 3840):
3840 in free list (128 min, 4096 max allowed)
676 hits, 0 misses, 0 trims, 0 created
Private particle pools:
IDS SM buffers, 240 bytes (total 128, permanent 128):
0 in free list (0 min, 128 max allowed)
128 hits, 0 fallbacks
128 max cache size, 128 in cache
0 hits in cache, 0 misses in cache
AIM-VPN/HPII-PLUS buffers, 544 bytes (total 768, permanent 768):
0 in free list (0 min, 768 max allowed)
768 hits, 676 fallbacks
768 max cache size, 256 in cache
219478220 hits in cache, 676 misses in cache
FastEthernet3/0 buffers, 1548 bytes (total 192, permanent 192):
0 in free list (0 min, 192 max allowed)
192 hits, 0 fallbacks
192 max cache size, 128 in cache
95580571 hits in cache, 0 misses in cache
FastEthernet3/1 buffers, 1548 bytes (total 192, permanent 192):
3235854 hits in cache, 0 misses in cache
FastEthernet4/0 buffers, 1548 bytes (total 192, permanent 192):
5678829 hits in cache, 0 misses in cache
FastEthernet4/1 buffers, 1548 bytes (total 192, permanent 192):
10353498 hits in cache, 0 misses in cache
GigabitEthernet0/0 buffers, 1664 bytes (total 768, permanent 768):
768 hits, 0 fallbacks
768 max cache size, 512 in cache
64302736 hits in cache, 0 misses in cache
14 buffer threshold, 0 threshold transitions
GigabitEthernet0/1 buffers, 1664 bytes (total 768, permanent 768):
1790387 hits in cache, 0 misses in cache
09-05-2013 02:08 PM
Actually that is not due to faulty cabling.
Router counts overruns as errors, even if they are valid packets on the wire.
And any error decreases reliability
09-05-2013 11:14 AM
Update IOS.
