informing administrator via sms
hamedyazdigss
Dr sir
i want to know is it possible to inform administrator via SMS when one interface is down. if else how we can be inform administrator about the status of the routers.
regards
hamed
guruprasadr
Level 7
Level 7
HI Hamed, [Pls rate if Helps]
I hope you require Microsoft SMS Server insalled in your network in which you have a feature to Poll the Network Interfaces Status. If the Interface is DOWN means there is an feature to send a SMS from the Server to inform respective Administrator about the Status.
Directly from Router is not Possible.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
8 Replies 8
guruprasadr
Level 7
Level 7
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Dear sir
thank you for your kind reply.i want to know if i install Microsoft SMS Server in my network can i define my routers interface to it in order if the interface is down send SMS to the Administrator.
please let me know your comment.
Best Regards,
Hamed
HI Hameed,
Yes you can too.
But, if you can give me sometime i can check for the same & provide your the necessary INFO.
Best Regards,
Guru Prasad R
Hi dear Sir
thank you so much.as you mentioned i am wating your kind information.
Best Regards.
Hamed
Hamed,
I have used the same in one of my customer premises where they were using the Microsoft SMS server which was connected to their exchange server as well. We had setup the Cellphones number as the exchange account and when the exchange server was getting an alert it was passing it to the SMS server to inform the administrator via SMS.
NMS servers doesnot have the option to fit in the cellphone number. My cell number was used as an email account like +919812345678@abc.com. The same address was set in the NMS as to sent the alerts via email. Whenever the alert was generated by the NMS it was sent to the exchange server which was relaying to the SMS server and in turn it was sent as an SMS to the administrator's cellphone.
It was Just a small note that I wanted to share with you..
-amit singh
I Recently attended a Cisco seminar where i was exposed to the the new cisco feature (Embedded event Manager) which can send an email directly from the device itself.
http://www.cisco.com/en/US/products/ps6815/products_qanda_item0900aecd803b1169.shtml
I know that it works with a 6500 but have no idea when that wil be extended as an IOS feature into all the devices
Maybe Amit can share more light on this :-)
Narayan
Hi Narayan
so many thanks for your kind reply.i checked exactly link that you meantioned,but i could not find something that related to sending SMS.i am looking how router's can inform administartor by the SMS.for example when the interface is down automatically router send the SMS.i will be happy if you let me know your comment.
best regards
Hamed
HI Hameed,
Please see the post of Amit Singh for easy/quick clarification on your Question.
Thanks to Amit Singh ! !
Posted by: asingh2 - Systems Engineer, CISCO SYSTEMS - Jul 13, 2007, 10:58am PST
Hamed,
-amit singh
Best Regards,
Guru Prasad R
