*Init* and *IP input* process high memory usage
Greg Maaaag
Good day!
We've got Cisco 881 and some why process *Init* uses most memory:
IT#show proc mem sorted allocated
Processor Pool Total:  156433128 Used:   45830872 Free:  110602256
      I/O Pool Total:   26214400 Used:    9815936 Free:   16398464
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  143673644   98177244   43180072          0          0 *Init*
106   0   11402608       6620      73676        780          0 IP Input
  64   0    2933316       2172    1422984          0          0 ESWPPM
   1   0    2160524          0    2167652          0          0 Chunk Manager
  96   8    2121716    1507700     613756          0          0 SSH Process
200   0    2079608    1818764     265172          0          0 Crypto IKMP
  12   0    1727040    1727040       7128          0          0 Licensing Auto U
266   0     981444          0     988572          0          0 l4f mgt task
196   0     557644     559820       7672          0          0 crypto sw pk pro
223   0     528608       6268     508668          0          0 VLAN Manager
  78   0     427492     423816      13116          0          0 crypto engine pr
199   0     358132     336924      34580       2268          0 Crypto IKE Dispa
  69   0     300756       2400     310260          0          0 EEM ED ND
214   0     273628          0     283756     100548          0 EEM ED Syslog
225   0     233608          0     240736          0          0 EEM Server
174   0     218404        660     215744          0          0 Crypto HW Proc
  74   0     131524        848     113132          0          0 USB Startup
190   0     106760        392     119496          0          0 Crypto IKEv2
204   0     100688      42292      83524          0          0 Crypto ACL
226   0      78088      28992      73880          0          0 Call Home proces
Is it ok?
jigojar
HI,
 Anyone can tell me that what *init* process will do in cisco routers?
Moath Hassonih
Init is a fixed value, that allocates memory when the router is booting and also reserve some memory if necessary for certain configurations/feature, this is a fix value and will not increase over the time . When the IOS boots, the system_init function runs which initializes all of the data structures, devices, configuration, etc . The amount of space taken by INIT depends on the configuration on the router.
