Initial Configuration. No internet access after NAT and Access rule - C897VA-K9
nidhinpk
I am trying to set up Internet access for C897VA-K9. Given below is the current configuration, Internal network is as 192.168.30.0 and internal is 182.0.0.5. I wish to set up S2S VPN with Azure gateway.. would like to know if this router supports that.
I am not able to ping the ISP gateway.
Current configuration : 2239 bytes
! Last configuration change at 20:27:22 UTC Thu Mar 28 2019
version 15.6
hostname CiscoHome
boot-start-marker
boot-end-marker
enable password >>>>
no aaa new-model
ethernet lmi ce
ip dhcp pool net
ip dhcp pool net-pool
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
dns-server 8.8.8.8 1.1.1.1
lease 9
ip cef
no ipv6 cef
license udi pid C897VA-K9 sn FGL224914TL
username admin password 0 >>>>>>>
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address 182.0.0.5 255.255.255.240
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip address 192.168.30.1 255.255.255.0
ip nat inside
no ip virtual-reassembly in
ip default-gateway 182.0.0.20
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat pool pool1 192.168.30.1 192.168.30.254 netmask 255.255.255.0
ip nat inside source list 1 pool pool1 overload
ip route 0.0.0.0 0.0.0.0 182.0.0.20
ip route 0.0.0.0 0.0.0.0 182.0.0.21
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
password cisco
no modem enable
line aux 0
line vty 0 4
password >>>>>
login
transport input telnet
line vty 5 15
password >>>>>>
login
scheduler allocate 20000 1000
end
I tried NAT Translation and its showing empty, Show NAT statistics and gave below output
CiscoHome#show ip nat stati
CiscoHome#show ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 0
Outside interfaces:
GigabitEthernet8
Inside interfaces:
Vlan1
Hits: 0 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 5] access-list 1 pool pool1 refcount 0
pool pool1: netmask 255.255.255.0
start 192.168.30.1 end 192.168.30.254
type generic, total addresses 254, allocated 0 (0%), misses 0
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
9 Replies 9
make the changes marked in bold to your configuration:
version 15.6
hostname CiscoHome
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp pool net
lease 9
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
--> no ip default-gateway 182.0.0.20
ip http server
--> no ip nat pool pool1 192.168.30.1 192.168.30.254 netmask 255.255.255.0
ip nat inside source list 1 interface GigabitEthernet8 overload
--> no ip route 0.0.0.0 0.0.0.0 182.0.0.20
--> no ip route 0.0.0.0 0.0.0.0 182.0.0.21
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
access-list 1 permit 192.168.30.0
control-plane
line con 0
password cisco
no modem enable
line aux 0
line vty 0 4
password >>>>>
login
line vty 5 15
password >>>>>>
login
end
I tried the above changes but still the same result. Attaching the running config along with this. Show ip nat translations doesnt show any result.
since this thread has been developing, not sure if that has been asked before, but do you have Internet connectivity at all ? Can you ping 8.8.8.8 from the router ?
Try to make the changes in bold to your configuration:
Current configuration : 2149 bytes
! Last configuration change at 23:32:16 UTC Thu Mar 28 2019
version 15.6
hostname CiscoHome
boot-start-marker
boot-end-marker
enable password Lankil12
no aaa new-model
ethernet lmi ce
ip dhcp pool net
lease 9
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
control-plane
line con 0
password cisco
no modem enable
line aux 0
line vty 0 4
password >>>>>
login
line vty 5 15
password ?>>>>
login
end
balaji.bandi
try below config :
lease 9
ip dhcp excluded-address 192.168.30.1
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip http server
no ip nat inside source list 1 pool pool1 overload
access-list 1 permit ip 192.168.30.0 0.0.0.255 any
Connect the PC and make sure you get DHCP IP from 192.168.30.x and ping 8.8.8.8
check :
#show ip nat translations
BB
Hi Thanks for the reply.
I am getting the below error while creating access list.
CiscoHome(config)#access-list 1 permit ip 192.168.30.0 0.0.0.255 any
Translating "ip"...domain server (255.255.255.255)
% Invalid input detected at '^' marker.
CiscoHome(config)#
The Command statement is incorrect:
access-list 1 permit 192.168.30.0 0.0.0.255
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Typo  issue - corrected as below
test and advise
BB
Hi @balaji.bandi
Here is the correct statement:
R1(config)#access-list 1 permit ?
  Hostname or A.B.C.D  Address to match
  any                  Any source host
  host                 A single host address
R1(config)#access-list 1 permit 192.168.1.0 0.0.0.255
R1(config)#ip access-list standard 1
R1(config-std-nacl)#?
Standard Access List configuration commands:
  <1-2147483647>  Sequence Number
  default         Set a command to its defaults
  deny            Specify packets to reject
  exit            Exit from access-list configuration mode
  no              Negate a command or set its defaults
  permit          Specify packets to forward
  remark          Access list entry comment
R1(config-std-nacl)#pe
R1(config-std-nacl)#permit ?
  any                  Any source host
R1(config-std-nacl)#permit 10.10.10.1 0.0.0.255 ?
  log  Log matches against this entry
  <cr>
Because Standard ACL will only work with the Source address.
Deepak Kumar
Deepak Kumar,
Hello
ip nat outside
First of all you have the wrong default route, its needs to be between 1-14 ,Sort this out first and test again connectivity you should at least be able to ping the next-hop even without NAT
You dont say what kind of vpn but 890 series router supports the following:
● Secure Sockets Layer (SSL) VPN for secure remote access
● Hardware-accelerated DES, 3DES, AES 128, AES 192, and AES 256
● Public-Key-Infrastructure (PKI) support
● Fifty IPsec tunnels
● Cisco Easy VPN Client and Server
● NAT transparency
● Dynamic Multipoint VPN (DMVPN)
● Tunnel-less Group Encrypted Transport VPN
Kind Regards
Paul
