How to make communication between different NIC in a server.
mbstevar1
Hi ,
We are having a server which is having two NIC and it is connected to different sub net.
but we are trying to communicate this two different sub nets through this server.
we are able to communicate from inside to out side. But, we could not able to communicate from out side to inside. Diagram.PNG
Please let me know what I need to do to communicate this two NICs, whether I need to put router are make bridge.
balaji.bandi
You need static route for this IP range 172.16.71.0/24 point to Server IP address.
BB
Deepak Kumar
Can you clear some more points?.
 How did you enable communication from inside to outside? Have you selected NATed mode (Window's Internet sharing option) under the NIC or using another "Routing and Policy Services" server role?
Is it a Window Server VM or Linux VM or Freeware Firewall or Freeware ROuting OS?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak,
1.We have a tunnel between Azure and our local network and added route
ip add 10.2.0.0/16 via 172.16.71.0/24
2.It linux which in cluster.
Hi Deepak,
