injecting a default-route by an ASBR into OSPF domain and reaching the ABR
Mehdi.a.majid1
What I want to do here is to generate a default-route on BR4 ( Totally NSSA ) which till this part it is simple
by
BR4(config-router)#area 4 nssa default-information-originate metric-type 1
and advertisement of this default-route reaches the HQ ( ABR & ASBR ) but the HQ does not consider it,
how can I make the HQ to consider it , what are the ways to do that ?
I appreciate any help that I can get.
54 Replies 54
I don't see how HQ and BR4 are forming an adjacency. The link between both appears to be 44.44.44.0/29, but the interfaces on which these addresses are configured are not part of any area.
Please clarify how you make HQ and BR4 be part of area 4.
Georg Pauwen
Thanks for replying
they are connected through Tunnel4
BR4#show ip ospf int bri
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
Tu4          1     4               10.4.4.4/24        1000  P2P   1/1
BR4#show ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
1.0.4.0           0   FULL/  -        00:00:32    10.4.4.1        Tunnel4
BR4#show ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         192.168.122.67  YES DHCP   up                    up
GigabitEthernet0/1         44.44.44.2      YES NVRAM  up                    up
GigabitEthernet0/2         192.168.40.1    YES manual up                    up
GigabitEthernet0/3         unassigned      YES NVRAM  administratively down down
Loopback4                  9.9.9.9         YES NVRAM  up                    up
NVI0                       192.168.122.67  YES unset  up                    up
Tunnel4                    10.4.4.4        YES NVRAM  up                    up
BR4#
HQ#show ip ospf interface brief
Gi0/2         1     0               172.16.2.1/29            1       BDR   1/1
Gi0/1         1     0               172.16.1.1/29            1       BDR   1/1
Tu123        1     1               192.168.123.1/28   1000    DR     2/2
Tu4            1     4               10.4.4.1/24             1000    P2P   1/1
HQ#
HQ#
HQ#show ip ospf neighbor
5.0.4.0           1   FULL/DR                 00:00:38    172.16.2.2          GigabitEthernet0/2
4.0.4.0           1   FULL/DR                 00:00:37    172.16.1.2          GigabitEthernet0/1
2.0.4.0           0   FULL/DROTHER       00:00:39    192.168.123.2   Tunnel123
3.0.4.0           0   FULL/DROTHER       00:00:31    192.168.123.3   Tunnel123
44.0.4.0          0   FULL/  -                  00:00:37    10.4.4.4             Tunnel4
HQ#
HQ#
HQ#show ip int
HQ#show ip interface br
HQ#show ip interface brief
GigabitEthernet0/0         1.1.1.2         YES NVRAM  up                    up
GigabitEthernet0/1         172.16.1.1      YES NVRAM  up                    up
GigabitEthernet0/2         172.16.2.1      YES NVRAM  up                    up
GigabitEthernet0/3         44.44.44.1      YES NVRAM  up                    up
GigabitEthernet0/4         192.168.122.160 YES DHCP   up                    up
Loopback1                  11.11.11.11     YES NVRAM  up                    up
Loopback4                  8.8.8.8         YES NVRAM  up                    up
NVI0                       11.11.11.11     YES unset  up                    up
Tunnel4                    10.4.4.1        YES NVRAM  up                    up
Tunnel123                  192.168.123.1   YES NVRAM  up                    up
HQ#
your default route, most likely, appears as an N1 route in the routing table of HQ:
O*N1 0.0.0.0/0 [110/1001] via 10.4.4.4, 00:00:09, Tunnel4
That means intra/inter/E1 routes will be considered first. What do you want to achieve ?
yes that is what I want to see in HQ routing table since I even get the advertisement of that type-7 default-route from BR4 but still I can't see a default-route ( O N1 ) int HQ routing table ,
HQ#show ip int bri
HQ#show ip route
Gateway of last resort is 192.168.122.1 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 192.168.122.1
      1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        1.1.1.0/30 is directly connected, GigabitEthernet0/0
L        1.1.1.2/32 is directly connected, GigabitEthernet0/0
      2.0.0.0/30 is subnetted, 1 subnets
S        2.2.2.0 [1/0] via 1.1.1.1
      3.0.0.0/30 is subnetted, 1 subnets
S        3.3.3.0 [1/0] via 1.1.1.1
      4.0.0.0/30 is subnetted, 1 subnets
S        4.4.4.0 [1/0] via 1.1.1.1
      8.0.0.0/32 is subnetted, 1 subnets
C        8.8.8.8 is directly connected, Loopback4
      9.0.0.0/32 is subnetted, 1 subnets
S        9.9.9.9 [1/0] via 44.44.44.2
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.4.4.0/24 is directly connected, Tunnel4
L        10.4.4.1/32 is directly connected, Tunnel4
      11.0.0.0/32 is subnetted, 1 subnets
C        11.11.11.11 is directly connected, Loopback1
      44.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        44.44.44.0/29 is directly connected, GigabitEthernet0/3
L        44.44.44.1/32 is directly connected, GigabitEthernet0/3
      172.16.0.0/16 is variably subnetted, 5 subnets, 3 masks
C        172.16.1.0/29 is directly connected, GigabitEthernet0/1
L        172.16.1.1/32 is directly connected, GigabitEthernet0/1
C        172.16.2.0/29 is directly connected, GigabitEthernet0/2
L        172.16.2.1/32 is directly connected, GigabitEthernet0/2
O        172.16.12.0/24 [110/2] via 172.16.2.2, 00:00:45, GigabitEthernet0/2
                        [110/2] via 172.16.1.2, 00:00:52, GigabitEthernet0/1
      192.168.122.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.122.0/24 is directly connected, GigabitEthernet0/4
L        192.168.122.160/32 is directly connected, GigabitEthernet0/4
      192.168.123.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.123.0/28 is directly connected, Tunnel123
L        192.168.123.1/32 is directly connected, Tunnel123
HQ#
HQ#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
HQ(config)#int g0/4
HQ(config-if)#shu
HQ(config-if)#shutdown
HQ(config-if)#
*Sep  8 20:09:05.108: %LINK-5-CHANGED: Interface GigabitEthernet0/4, changed state to administratively down
*Sep  8 20:09:06.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/4, changed state to down
HQ(config-if)#do show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
O        172.16.12.0/24 [110/2] via 172.16.2.2, 00:02:10, GigabitEthernet0/2
                        [110/2] via 172.16.1.2, 00:02:17, GigabitEthernet0/1
HQ(config-if)#
HQ#show ip ospf database
            OSPF Router with ID (1.0.4.0) (Process ID 1)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
1.0.4.0         1.0.4.0         435         0x80000005 0x0040D2 2
4.0.4.0         4.0.4.0         441         0x80000004 0x0012B4 2
5.0.4.0         5.0.4.0         440         0x80000004 0x002A98 2
                Net Link States (Area 0)
172.16.1.2      4.0.4.0         441         0x80000001 0x00105C
172.16.2.2      5.0.4.0         436         0x80000003 0x00FE68
                Summary Net Link States (Area 0)
10.4.4.0        1.0.4.0         431         0x80000001 0x00B980
192.168.123.0   1.0.4.0         431         0x80000001 0x003E38
                Router Link States (Area 1)
1.0.4.0         1.0.4.0         437         0x80000002 0x00342F 1
                Summary Net Link States (Area 1)
172.16.1.0      1.0.4.0         439         0x80000001 0x00B3CC
172.16.2.0      1.0.4.0         439         0x80000001 0x00A8D6
172.16.12.0     1.0.4.0         439         0x80000001 0x006EFE
                Router Link States (Area 4)
1.0.4.0         1.0.4.0         432         0x80000005 0x00568A 2
44.0.4.0        44.0.4.0        438         0x80000005 0x00991A 2
                Summary Net Link States (Area 4)
0.0.0.0         1.0.4.0         439         0x80000001 0x00141D
                Type-7 AS External Link States (Area 4)
Link ID         ADV Router      Age         Seq#       Checksum Tag
0.0.0.0         44.0.4.0        1165        0x80000001 0x007271 0
8.8.8.8         44.0.4.0        1166        0x80000002 0x0089A1 4
so I believe that I should have that O*N1 default-route in HQ routing table , so the question is why I don't?
and to achieve that what are the ways ?
Thanks.
change the static route on BR4 from:
ip route 0.0.0.0 0.0.0.0 192.168.122.1 22
to
ip route 0.0.0.0 0.0.0.0 null 0
I did it but no result,
I add another Router (ISP1) to the BR4 which receives the default-route by BGP and again it is the same and HQ does receive the type-7 default-route but it does not add it to its routing table.
remove the 'redistribute static' from your OSPF on BR4:
router ospf 1
router-id 44.0.4.0
--> no redistribute static subnets tag 4
network 10.4.4.4 0.0.0.0 area 4
Heloo,
Thanks for the help.
I did that but it didn't work either.
but I could achieve it by going to the HQ and issuing #no area 4 nssa no-summary and # area 4 nssa
as follows :
HQ(config-router)#do show ip ospf data sum
  LS age: 82
  Options: (No TOS-capability, DC, Upward)
  LS Type: Summary Links(Network)
  Link State ID: 5.0.0.4 (summary Network Number)
  Advertising Router: 1.0.4.0
  LS Seq Number: 80000001
  Checksum: 0x271E
  Length: 28
  Network Mask: /30
        MTID: 0         Metric: 1001
  LS age: 645
  Link State ID: 10.4.4.0 (summary Network Number)
  Checksum: 0xB980
  Length: 28
  Network Mask: /24
        MTID: 0         Metric: 1000
  LS age: 600
  Link State ID: 192.168.1.0 (summary Network Number)
  Checksum: 0xE877
  Length: 28
  Network Mask: /25
  LS age: 600
  Link State ID: 192.168.1.128 (summary Network Number)
  Checksum: 0xE3FB
  Length: 28
  Network Mask: /25
  LS age: 610
  Link State ID: 192.168.2.0 (summary Network Number)
  Checksum: 0xDD81
  Length: 28
  Network Mask: /25
  LS age: 610
  Link State ID: 192.168.2.128 (summary Network Number)
  Checksum: 0xD806
  Length: 28
  Network Mask: /25
  LS age: 82
  Link State ID: 192.168.40.0 (summary Network Number)
  Checksum: 0x3AFE
  Length: 28
  Network Mask: /25
  LS age: 645
  Link State ID: 192.168.123.0 (summary Network Number)
  Checksum: 0x3E38
  Length: 28
  Network Mask: /28
  LS age: 82
  Checksum: 0x271E
  Length: 28
  Network Mask: /30
  LS age: 645
  Checksum: 0xB980
  Length: 28
  Network Mask: /24
  LS age: 645
  Link State ID: 172.16.1.0 (summary Network Number)
  Checksum: 0xB3CC
  Length: 28
  Network Mask: /29
        MTID: 0         Metric: 1
  LS age: 645
  Link State ID: 172.16.2.0 (summary Network Number)
  Checksum: 0xA8D6
  Length: 28
  Network Mask: /29
        MTID: 0         Metric: 1
  LS age: 645
  Link State ID: 172.16.12.0 (summary Network Number)
  Checksum: 0x6EFE
  Length: 28
  Network Mask: /24
        MTID: 0         Metric: 2
  LS age: 82
  Checksum: 0x3AFE
  Length: 28
  Network Mask: /25
  LS age: 93
  Link State ID: 0.0.0.0 (summary Network Number)
  Checksum: 0xC342
  Length: 28
  Network Mask: /0
        MTID: 0         Metric: 44
1.0.4.0         1.0.4.0         667         0x80000008 0x003A9C 2
5.0.4.0         5.0.4.0         1559        0x80000005 0x002899 2
172.16.2.2      5.0.4.0         1559        0x80000003 0x00FE68
5.0.0.4         1.0.4.0         94          0x80000001 0x00271E
10.4.4.0        1.0.4.0         657         0x80000001 0x00B980
192.168.1.0     1.0.4.0         611         0x80000001 0x00E877
192.168.1.128   1.0.4.0         611         0x80000001 0x00E3FB
192.168.2.0     1.0.4.0         621         0x80000001 0x00DD81
192.168.2.128   1.0.4.0         621         0x80000001 0x00D806
192.168.40.0    1.0.4.0         94          0x80000001 0x003AFE
192.168.123.0   1.0.4.0         657         0x80000001 0x003E38
1.0.4.0         1.0.4.0         626         0x8000000B 0x0073F1 1
2.0.4.0         2.0.4.0         626         0x8000000C 0x00F4F6 3
3.0.4.0         3.0.4.0         627         0x8000000B 0x0025C2 3
192.168.123.1   1.0.4.0         621         0x80000002 0x000344
172.16.1.0      1.0.4.0         657         0x80000001 0x00B3CC
172.16.2.0      1.0.4.0         657         0x80000001 0x00A8D6
172.16.12.0     1.0.4.0         657         0x80000001 0x006EFE
1.0.4.0         1.0.4.0         98          0x8000000A 0x004C8F 2
44.0.4.0        44.0.4.0        99          0x80000009 0x007EF2 4
0.0.0.0         1.0.4.0         105         0x80000001 0x00C342
0.0.0.0         44.0.4.0        249         0x80000001 0x00E40B 0
8.8.4.0         44.0.4.0        241         0x80000004 0x006DEA 0
                Type-5 AS External Link States
8.8.4.0         1.0.4.0         93          0x80000001 0x008C04 0
HQ(config-router)#do show ip route
      5.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
O        5.0.0.4/30 is a summary, 00:01:46, Null0
O        5.0.0.5/32 [110/1001] via 10.4.4.4, 00:01:46, Tunnel4
      8.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
O N2     8.8.4.0/24 [110/1] via 10.4.4.4, 00:01:46, Tunnel4
C        8.8.8.8/32 is directly connected, Loopback4
O        172.16.12.0/24 [110/2] via 172.16.2.2, 00:01:57, GigabitEthernet0/2
      192.168.1.0/25 is subnetted, 2 subnets
O        192.168.1.0 [110/1001] via 192.168.123.2, 00:01:57, Tunnel123
O        192.168.1.128 [110/1001] via 192.168.123.2, 00:01:57, Tunnel123
      192.168.2.0/25 is subnetted, 2 subnets
O        192.168.2.0 [110/1001] via 192.168.123.3, 00:01:57, Tunnel123
O        192.168.2.128 [110/1001] via 192.168.123.3, 00:01:57, Tunnel123
      192.168.40.0/25 is subnetted, 1 subnets
O        192.168.40.0 [110/1001] via 10.4.4.4, 00:01:46, Tunnel4
HQ(config-router)#do show run | sec ospf
 ip ospf 1 area 4
 ip ospf network broadcast
 redistribute ospf 1 metric 100 5000 255 2 17916
router ospf 1
 router-id 1.0.4.0
 area 4 default-cost 44
 area 4 range 5.0.0.4 255.255.255.252
 redistribute eigrp 100 metric-type 1 subnets tag 100
 network 172.16.1.0 0.0.0.7 area 0
 network 172.16.2.0 0.0.0.7 area 0
 network 192.168.123.0 0.0.0.15 area 1
HQ(config-router)#no area 4 nssa no-summary
 ip ospf 1 area 4
router ospf 1
 router-id 1.0.4.0
 area 4 nssa
Gateway of last resort is 10.4.4.4 to network 0.0.0.0
O*N1  0.0.0.0/0 [110/1002] via 10.4.4.4, 00:00:18, Tunnel4
O        5.0.0.4/30 is a summary, 00:00:18, Null0
O        5.0.0.5/32 [110/1001] via 10.4.4.4, 00:00:18, Tunnel4
O N2     8.8.4.0/24 [110/1] via 10.4.4.4, 00:00:18, Tunnel4
O        172.16.12.0/24 [110/2] via 172.16.2.2, 00:00:18, GigabitEthernet0/2
O        192.168.1.0 [110/1001] via 192.168.123.2, 00:00:18, Tunnel123
O        192.168.1.128 [110/1001] via 192.168.123.2, 00:00:18, Tunnel123
O        192.168.2.0 [110/1001] via 192.168.123.3, 00:00:18, Tunnel123
O        192.168.2.128 [110/1001] via 192.168.123.3, 00:00:18, Tunnel123
O        192.168.40.0 [110/1001] via 10.4.4.4, 00:00:18, Tunnel4
HQ(config-router)#
So I think the reason is that since the HQ will automatically advertises a default-route into totally NSSA and because of that it doesn't consider the default-route info received from BR4 ( I also issued #area 4 default-cost 44 , which had no effect to prefer the BR4's default-route) , so when I configured the area 4 just as NSSA on HQ then it is able to accept and consider the BR4's default-route and put it in its routing table.
Now the question is that how can I do have that default-route in HQ's routing table if the area 4 be configured as totally NSSA ?
Thanks again.
Hello
i am not able to view all the reply’s at present but just reading your OP if your peering ospf over tunnel is if that tunnel assigned to backbone area 0 ?
Kind Regards
Paul
no it is assigned to to area 4
HQ#show ip ospf int bri
Gi0/2         1        0               172.16.2.1/29            1        DR     0/0
Gi0/1         1        0               172.16.1.1/29            1        DR     0/0
Tu123        1        1               192.168.123.1/28     1000   DR     1/1
Hello
If your trying to inject a default route into area 0 from a non backbone nssa - my understanding it will not be allowed
Kind Regards
Paul
it does not allow when HQ knows the area 4 as totally NSSA but it allows that when HQ knows the area 4 as NSSA and BR4 has an actual default-route through BGP and is redistributed to ospf .
But I wanted to do so i.e I want to have that default-route usable in HQ advertised by BR4 to HQ which I can see that HQ can receive the advertisement of that default-route but does not consider it , since HQ considers the other redistributed routes from BGP into ospf by BR4 .
so by your understanding :
HQ(ABR & ASBR)  won't accept default-route advertised by BR4 ( area 4) and it is not possible if the area 4 is Totally NSSA ?!
I recreated your setup in GNS3, with back to back routers, the default route is injected as expected on HQ:
HQ
interface Loopback4
ip address 8.8.8.8 255.255.255.255
interface Tunnel4
ip address 10.4.4.1 255.255.255.0
ip ospf 1 area 4
tunnel source Loopback4
tunnel destination 9.9.9.9
interface GigabitEthernet0/0
ip address 44.44.44.1 255.255.255.248
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 8.8.8.8
ip route 9.9.9.9 255.255.255.255 44.44.44.2
BR4
interface Loopback4
ip address 9.9.9.9 255.255.255.255
interface Tunnel4
ip address 10.4.4.2 255.255.255.0
ip ospf 1 area 4
tunnel destination 8.8.8.8
ip address 44.44.44.2 255.255.255.248
duplex auto
speed auto
media-type rj45
no cdp enable
router ospf 1
area 4 nssa default-information-originate no-summary
ip route 0.0.0.0 0.0.0.0 Null0
ip route 8.8.8.8 255.255.255.255 44.44.44.1
HQ#sh ip route
Gateway of last resort is 10.4.4.2 to network 0.0.0.0
O*N2 0.0.0.0/0 [110/1] via 10.4.4.2, 00:03:01, Tunnel4
C 44.44.44.0/29 is directly connected, GigabitEthernet0/0
L 44.44.44.1/32 is directly connected, GigabitEthernet0/0
Thanks.
I did a separate GNS3 with just 3 routers ( (VIOS-ADVENTERPRISEK9-M), Version 15.6(2)T ) just for area 0 and 4 but the result is still the same .
I don't get it !
