Input Erros - But no details
Harald S
i'm wondering about an interface on an ASR920.
GigabitEthernet0/0/7 is up, line protocol is up
Hardware is 24xGE-4x10GE-FIXED-S, address is XXXX.XXXX.XXXX (bia XXXX.XXXX.XXXX)
Description: *** XXXXXXX ***
MTU 9000 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full Duplex, 1000Mbps, link type is auto, media type is LX
output flow-control is unsupported, input flow-control is on
Carrier delay is 0 msec
Last input never, output 00:00:02, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 1688000 bits/sec, 312 packets/sec
30 second output rate 2015000 bits/sec, 320 packets/sec
5438829966 packets input, 4764810553374 bytes, 0 no buffer
Received 643624214 broadcasts (0 IP multicasts)
21299 input errors, 11 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 352452432 multicast, 0 pause input
2647783744 packets output, 1049807216626 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Input error is increasing. But nearly no CRC and no other errors. What`s going wrong to increase the Input Error Counter?
BR
Harald
balaji.bandi
what is the other device connected to this port, do you see same errors other side, any impact on performance ?
what is the version code running on this device.
BB
I don't know anything about the connected device. (Customer equipment)
show version:
Cisco IOS XE Software, Version 03.18.03.SP.156-2.SP3-ext
Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.6(2)SP3, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Tue 19-Sep-17 22:12 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2017 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
mr012.fn uptime is 2 years, 7 weeks, 6 days, 13 hours, 5 minutes
Uptime for this control processor is 2 years, 7 weeks, 6 days, 13 hours, 7 minutes
System returned to ROM by reload at 04:35:07 CET Wed Jan 10 2018
System restarted at 04:50:03 CET Wed Jan 10 2018
System image file is "bootflash:asr920-universalk9_npe.03.18.03.SP.156-2.SP3-ext.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: advancedmetroipaccess
License Type: Permanent
Next reload license Level: advancedmetroipaccess
cisco ASR-920-24SZ-M (Freescale P2020) processor (revision 1.2 GHz) with 900304K/6147K bytes of memory.
Processor board ID CATXXXXXXXX
24 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1328927K bytes of SD flash at bootflash:.
