Inrease Buffer on CSR to have more output , when i issue : sh history
Ibrahim Jamil
Level 6
Level 6
Hello guys
how to increase the buffer log size in order to have more command appear when i issue "sh history"
thanks
2 Accepted Solutions
 Hi @Ibrahim Jamil
Try 'terminal history size "size"'
-If I helped you somehow, please, rate it as useful.-
you can also set the history size under each line. This is saved to NVRAM and available after a reboot (whereas as far as I recall 'terminal history size' is not saved to NVRAM)...
line vty 0 4
history size 200
line con 0
history size 200
line aux 0
history size 200
 Hi @Ibrahim Jamil
line vty 0 4
history size 200
line con 0
history size 200
line aux 0
history size 200
Thanks All
