inside traffic not routing to backup wan interface when primary down
ctimm
This is on an ASA 5516, ASA Version 9.16(3)19
I've configured a backup interface for our backup ISP following this documentation:
Configure the ASA for Redundant or Backup ISP Links - Cisco
The problem is that when the primary is down, traffic from the inside isn't routing through the backup interface.
I have this network object:
object network obj_any
subnet 0.0.0.0 0.0.0.0
nat (any,outside) dynamic interface
If I add:
object network obj_any_backup
nat (any,outside-backup) dynamic interface
it isn't routing. The same, if I change the 1st to:
this doesn't work either.
Is there something incorrectly configured or am I missing any configuration?
25 Replies 25
Not adding twice
First line is what I enter in conf t
Second is the result of trying to add route-lookup where it errs
I have not followed the entire thread, but make sure your config looks like below:
subnet in.in.in.in 255.255.255.0
nat (inside,outside) dynamic interface
nat (inside,outside-backup) dynamic interface
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address pri.pri.pri.pri 255.255.255.x
interface GigabitEthernet1/2
nameif inside
security-level 100
ip address in.in.in.in 255.255.255.0
interface GigabitEthernet1/3
nameif outside-backup
security-level 0
ip address bak.bak.bak.bak 255.255.255.x
route outside 0.0.0.0 0.0.0.0 pri.pri.pri.gw 1 track 1
route outside-backup 0.0.0.0 0.0.0.0 bak.bak.bak.bakgw 254
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:30
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
sla monitor 123
type echo protocol ipIcmpEcho 1.1.1.1 interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
Hello
nat (any,outside) dynamic interface route-lookup
Change your nat statement to specify the inside interface and not any interface, apart from that you CFG looks okay
nat (inside,outside) dynamic interface route-lookup
nat (inside,backup) dynamic interface route-lookup
Kind Regards
Paul
Lab I run and full success
ctimm
Unfortunately, no dice on all of the above.
Added note, if I go to an IP address detection site after forcefully failing over, it briefly will load and show the backup interface IP address but then stops.
I'm going to dig into this deeper on the LAN side and see if there may be some wfw rule, something on the switches, or something else on the internal that might be blocking this route.
Just doesn't make sense.
can I see the ASA config ??
Just sent you a DM with the code - It's long and didn't want to post openly on this thread
I receive it, I will check
sla monitor 123
type echo protocol ipIcmpEcho 1.1.1.1 interface outside <<-10.10.10.1 change the IP you ping to this one.
also please do
nat (inside,outside-backup) after-auto source dynamic any interface
nat (inside,outside) after-auto source dynamic any interface
remove below NAT
Sorry, still not routing outside with these changes.
I understand the type echo portion and that isn't part of the issue.
I've configured exactly as described, but to force outside-backup, I've used an IP that I know won't respond to requests and mark it as down.
This still doesn't route inside to 0.0.0.0 0.0.0.0
I have one point I need to check, I will update soon
