Install License on Cisco 1921 with USB
Hello Community
Can someone please show me how install a .lic file onto the new Cisco ISR G2 1921?
I know how to install via tftp, however I need to know how to install from USB.
Your help will be greatly appreciated.
Cheers
When I attempt to copy from usb with the following commands are the following error:(destination path is identical)
yourname#cop usbflash0: fla
yourname#cop usbflash0: flash:
Source filename [usbflash0]? FCZ1716933D_20130513014106144.lic
Destination filename [FCZ1716933D_20130513014106144.lic]?
%Error copying usbflash0:/FCZ1716933D_20130513014106144.lic (destination path is identical)
usbflash0: and flash: are the same on the 1921.
If you have the license on an external usb device it is usbflash1:
Cisco-1921#sh file systems
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
     265644032     198498304  usbflash     rw   usbflash1:
*    256610304     116572160  usbflash     rw   usbflash0: flash:
mohittiwari
Try this
Router#copy usbflash0 flash:
Source filename
paolo bevilacqua
license install .
Copy without doing the above is useless.
You can also read documentation on the subject.
