QoS on the WAN
royalblues
Level 10
Level 10
This is the current QoS configuration on my WAN edge
policy-map MPLS-EDGE
class MPLS-VOICE
priority percent 25
class-map match-any MPLS-VOICE
match ip dscp ef
match ip precedence 5
int fa 0/1
bandwidth 4096
service-policy output MPLS-EDGE
When i do a priority percent 25, does my scavenger class gets the remaining 75% or should i explicitly add another class like the one mentioned below
class-map match-all Scavenger
match access-group 100
access-list 100 permit ip any any
class MPLS-VOICE
priority percent 25
Class Scavenger
Bandwidth percent 65
Narayan
6 Replies 6
tdrais
Level 7
Level 7
There is a class called class-default that will get anything that is not committed to anything else. There is no need to configure one since you can put any options in that class.
I suspect the example you give will not work as you intend. The percent keyword works off the bandwidth statement. This will cause in your case 1024k to be reserved. The issue is this is really only 10% if a fast ethernet interface. The bandwidth statement does not have any effect on how much data actually passes though a interface.
To avoid issues with routing protocols like OSPF and to not get confusing reports from tools that use this number to calculate utilization I would always set the bandwidth correctly and make my QoS setting correspond.
If you intention was to limit the traffic using the bandwidth statement you will need to use a traffic shaper to limit the traffic to 4 m and then apply the QoS within the shaping.
Tim,
Does the class default maps the remianing 75% of the bandwidth to it?
Actually i have an 4 MB MPLS circuit connecting to the fastethernet interface (ehthernet handoff) and that is why the bandwidth statement.
My topology looks something like this
Access---Core/distribution---WAN edge router
I am planning to mark all the voice traffic to DSCP ef and the rest to scavenger class at the core switch and forward it across.
Narayan
Other than a small amount of router traffic that is not in any class all traffic that does not fall in another class goes into the default class.
In your case it is confusing to say 75% but in a very broad sense it will. Since the ethernet port can run at 100m and you have reserved 1m (ie 25% of 4096k) the remaining 99m goes into class default which is 99%. So you reserved 1m which is 1% of the interface but 25% of the declared bandwidth. I tend to use explict reservations when I do priority queueing rather than percent to avoid someone changing my bandwidth to try to influence the routing and screwing up the QoS.
In your case as long your MPLS provider will honor you EF markings and you have at least 1m of guarenteed low latency in your contract it will work. If you were to send 10m of traffic for a sustained time the provider should always pass the 1m voice traffic and drop up to 7m of the other. If your MPLS provider limits you to 4m before it looks at the packet markings you could have issues.
I tend to like to control which traffic is dropped myself so I would shape the traffic to 4m before it left my router.
To limit the traffic to 4m you would do
policy-map shape01
class class-default
shape average 4000000
service policy MPLS-EDGE
You would apply the shape01 to the fast ethernet interface.
Even the above example is using the class-default which since there are no other class statements is 100%.
With the shaping in place your priority class still has 1m but the class-default within your MPLS-EDGE policy is now limited to 3m which is correctly corresponds to 75% if you want to look at the number that way.
Thanks Tim,
Mostly i think the service provider rate limits the bandwidth before looking at the packet markings.
I always run into issues even with 3-4 calls during peak utilization
So should i reconfigure the QoS to something like this
class MPLS-VOICE
priority percent 25
match ip dscp ef
int fa 0/1
bandwidth 4096
I think my QoS settings are anyway not getting implemeted properly as i always receive complaints during peak traffic.
I have 8 different sites connecting to the MPLS cloud each at a different rate. I think i should shape the traffic at each location to the bandwidth limited by the provider.
I can provide the network topolgy if you want.
Narayan
That is more or less correct. I don't think you can apply the shaping directly to the interface.
This is a document discussing how to apply QoS to a ethernet subinterface. It is done the same way on a physical interface.
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a0080114326.shtml
Look at the example under the title
Applying a Hierarchical Policy
This is similar to your case.
Tim,
That was a typo.. i would shape the traffic via a policy & a Class.
Mostly when i read about shaping it mentioned as to be used for non real time traffic. so if i use priority as well as the shape command, would it affect my VoIP traffic if the interafce starts queuing the voice packets
Narayan
