Installing New NPE in a 7206
vpresher
I am going to need to upgrade my 7206 to an NPE with more memory. I currently have a NPE 200 installed with 128meg. Are there any limitiations on the router itself that would have to be considered in order to go to a NPE 300 or greater?
pkhatri
Level 11
Level 11
What sort of a 7206 do you have ? Is it a VXR model ?
The 72xx non-VXR models only support the following:
NPE-100, NPE-150, NPE-175, NPE-200, and NPE-225
The 7206VXRs, on the other hand, support all NPE models.
Hope that helps - pls rate the post if it does.
Paresh
