user acces to router
imnilesh
Hi;
In my enterprise network we having 55 locationa sn each location is connected to data center by 1800 router and each locatin we have FM engineer to manage the localsite.
my problem is we maninatn the amdn amnage the outer from data centre but some time we have to give acess to local Fm engineer to router.
for this can we have one user with specific rights for some command to run on router...if yes i want to give following rights for local engineer to see the router status i.e:
sh int s0/0
sh ip account output
sh int bri0/0
sh isdn act
thanks in advance.....
jorrala
hi,
Esta configuración lo puede ayudar:
username xxxx privilege 15 password xxxx
username xxxx privilege 5 password xxxx
privilege exec level 5 show interfase
privilege exec level 5 show ip accounting
privilege exec all level 5 show
line vty 0 4
password xxxx
login
thisisshanky
Level 11
Level 11
Please check Privilege levels that work with AAA to make this to work.
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a008009465c.shtml
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
jarathbu
This can be done by assigning the commands to specific privilege levels and granting the FM engineer a login with the same privilege level. Additional information can be found:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00803f3bb7.html
Also, if using an AAA solution to allow for local authentication as a fallback method in case the link is down and you need the FM engineer to access. Another option would be to have an out-of-band connection (e.g. modem) to the console of the router and you can dial-in and get the necessary outputs.
Hope this helps.
James
in addition to James´ and Sankar´s posts, you could also configure a menu, which is sort of a user-friendly screen with options from which your firewall engineer can choose. In the sample configuration below, the firewall engineer would logon to the router with the following command:
telnet x.x.x.x 3001
where x.x.x.x is the IP address of the router. Only one VTY (Telnet) line is reserved for the firewall engineer, leaving the other 4 VTY lines for you to access. Just make sure that when you try to telnet to the router, you specify another port (e.g. telnet x.x.x.x 3002).
When your firewall engineer logs on to the router with the username FW and the corresponding password, he (or she) will automatically be presented with the menu.
Obviously you will need to tell your engineer to use the (port 3001 in this example) correct syntax when telnetting, in order for the access to work correctly.
username FW password 0 cisco
username FW autocommand menu LOCALSITE
menu LOCALSITE title "Menu for FW engineers"
menu LOCALSITE prompt "Choose your selection: "
menu LOCALSITE text 1. Show interface serial0/0
menu LOCALSITE command 1. show interfaces serial0/0
menu LOCALSITE options 1. pause
menu LOCALSITE text 2. Show ip accounting output
menu LOCALSITE command 2. show ip accounting output
menu LOCALSITE options 2. pause
menu LOCALSITE text 3. Show interface bri0/0
menu LOCALSITE command 3. show interfaces bri0/0
menu LOCALSITE options 3. pause
menu LOCALSITE text 4. Show isdn active
menu LOCALSITE command 4. show isdn active
menu LOCALSITE options 4. pause
menu LOCALSITE text 5. Exit
menu LOCALSITE command 5. exit
menu LOCALSITE clear-screen
line vty 0
login local
rotary 1
Moving commands to a specific privilege level, as mentioned by James, would look like this (again, only one VTY line is reserved for your firewall engineer). In this sample configuration, the commands you specified are moved to the lowest exec level (0). When your firewall engineer telnets to the router with:
telnet x.x.x.x 3001
the engineer would remain in user mode, but be able to execute the commands that have been moved to that exec level:
username FW privilege 0 password cisco
privilege exec level 0 show interfaces
privilege exec level 0 show ip accounting
line vty 0
login local
privilege level 0
rotary 1
Nethelper
jorrala
hi,
line vty 0 4
password xxxx
login
