ip load balance per-packet
conectividade
Hi, Messrs!
I have 4 links of 2Mbps connecting two routers, I would like
to make load balance per packet, but it doesn't works well.
The inbound traffic is load balanced, but the
outbound traffic doesn't work well.
Below I send my cfg (the other router I don't have configuration).
What could be wrong?
ip cef
interface Serial0/0
description XXX-0
bandwidth 2048
ip address xxx.xxx.xxx.xx6 255.255.255.252
no ip redirects
no ip unreachables
ip nat outside
ip load-sharing per-packet
ip route-cache flow
no ip mroute-cache
load-interval 30
no fair-queue
no cdp enable
interface Serial0/1
description XXX-1
bandwidth 2048
ip address xxx.xxx.xxx.xx2 255.255.255.252
no ip redirects
no ip unreachables
ip nat outside
ip route-cache flow
no ip mroute-cache
load-interval 30
no fair-queue
no cdp enable
interface Serial0/2
description xxx-2
bandwidth 2048
no ip redirects
no ip unreachables
ip nat outside
ip route-cache flow
no ip mroute-cache
load-interval 30
no fair-queue
no cdp enable
interface Serial0/3
description xxx-3
bandwidth 2048
ip address xxx.xxx.xxx.xx8 255.255.255.252
no ip redirects
no ip unreachables
ip nat outside
ip route-cache flow
no ip mroute-cache
load-interval 30
no fair-queue
no cdp enable
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xx1
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xx5
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xx7
thanks,
Renato
9 Replies 9
pkhatri
Level 11
Level 11
Hi Renato,
Are you sure it's the inbound traffic that is load-balanced properly and not the outbound. It's just that with the config you have, the outbound traffic should be load-balanced in a per-packet manner but you would not have any control over inbound traffic if you don't own the other router you are connected to.
Unless you have specific arrangements in place, you can only influence the traffic that you yourself send out.. inbound traffic will come in through whatever mechanism is used by the router at the other end.
Hope that helps - pls rate the post if it does.
Paresh
Renato
Perhaps you can clarify some aspects of the addressing:
interface Serial0/0
interface Serial0/1
interface Serial0/2
interface Serial0/3
From this config it looks like serial0/0 and serial0/2 might be defining the same subnet. Perhaps you can clarify the addressing of the interfaces and the next hops of the static routes.
Perhaps there is an alternative that you might consider which is multilink. If you configure all four interfaces in a multilink bundle you will get the benefit of aggregate bandwidth, equal usage of the interfaces, and will not have the potential of out of order packets which per packet load balancing introduces.
Rick
Rick
saimbt
Try removing the command ip cef.
-Sai.
Disabling CEF would cause the router to revert to a lesser switching algorithm.
The configuration presented looks correct for cef per packet load balancing.
Additional info can be found at:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080430ac3.html#wp1046601
I agree with the previous posts. That the router will make the decision for load-balancing outbound traffic and you will have little (or no control) depending on the admistrative domain (admin control) of the router(s) on both sides. Also as previously mentioned you can investigate using MPPP to aggregate the bandwidth.
Hope this helps.
James
Thank you a lot!
I will investigate about MPPP.
looking at your initial configuration, and since you are NATting, you might want to try the following (assuming that you are overloading, and assuming that your internal address space is network 192.168.1.0/24, change that accordingly if your address space is different):
ip nat inside source route-map SERIAL0/1 interface serial0/1 overload
ip nat inside source route-map SERIAL0/2 interface serial0/2 overload
ip nat inside source route-map SERIAL0/3 interface serial0/3 overload
ip nat inside source route-map SERIAL0/4 interface serial0/4 overload
access-list 1 permit 192.168.1.0
route-map SERIAL0/1 permit 10
match ip address 1
match interface serial0/1
route-map SERIAL0/2 permit 10
match ip address 1
match interface Serial0/2
route-map SERIAL0/3 permit 10
match ip address 1
match interface Serial0/3
route-map SERIAL0/4 permit 10
match ip address 1
match interface Serial0/4
ip route 0.0.0.0 0.0.0.0 Serial0/1
ip route 0.0.0.0 0.0.0.0 Serial0/2
ip route 0.0.0.0 0.0.0.0 Serial0/3
ip route 0.0.0.0 0.0.0.0 Serial0/4
Nethelper
mjones-f1
I had the same problem...got it to work with ppp multilink:
interface Multilink1
ip address 172.20.1.5 255.255.255.252
fair-queue 256 256 0
ppp multilink
no ppp multilink fragmentation
multilink-group 1
interface Serial0/0
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
interface Serial0/1
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
But isn´t the config of mppp an issue where both ends need being configed?
So config the router for mppp doesn´t do any good (on the contrary) since the other end isn´t configed. And your lines will probably be in down mode.
-- Lars
Sorry, I left out that the other side has the same configuration except the Multilink1 interface has a different ip address.
