installing V.92 on the router
cisco steps
is installing The Cisco Integrated V.92 Modem WAN Interface on the router for remote access will cause security concern, and one more question , How do you find if there is a modem connected and configured on the router . Thanks
Phillip Remaker
Any time you connect a device to a network, you have a security concern!  Just ensure that you have password or AAA protection on the line.
See http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_configuration_example09186a0080204528.shtml
mavespig
Level 3
Level 3
once the modem card is installed, you should see in configuration a new Async interface appearing.
You can apply all the configuration, including security commands, under that interface.
For configuration steps, you may refer to this document:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gt12pwi8.html
Cheers
Marco
