installing WIC-1ENET
oattoumani
HI,
The software Advisor indicate me the IOS 12.1.27b (IP) for installing a WIC-1ENET in cisco 1750 router.
But the install abort with this message "PQUICC-1-UNKNOWN_WIC: PQUICC(0), WIC card has an unknown ID of 0xFF".
The router has 4M of Flash and 16M of DRAM memory and the show version indicates:
" cisco 1750 (MPC860) processor (revision 0x601) with 12288K/4096K bytes of memory
Processor board ID JAD05060L4Y (2619670584), with hardware revision 3097
M860 processor: part number 0, mask 32 "
Is it necessairy change the router chassis; or a simple upgrad for IOS and Memory; will be compatible for the WIC-1ENET?
sincerly.
Omar ATTOUMANI
5 Replies 5
leonvd79
Level 4
Level 4
Perhaps this is a useful resource to resolve your problem:
http://www.certfaq.com/bb/sutra95072.html
Read from bottom up!
beast_gts
WIC-1ENET requires a minimum IOS version of 12.2(4)T, which requires 8MB flash.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/1700/1700cnts/cn1enet.pdf
Not applicable
Not applicable
Not applicable
