%Insufficient resources to create channel group
mattsmith
We installed a NM-HD-2VE on slot 1 of a 3825 Router
We installed a VIC-4FXS/DID in wic 0
     Ports are working fine.
We installed a VWIC2-2MFT-T1/E1 in wic 1
     Port 1/1/0 is working fine as a data port.
     Port 1/1/1 gives the error message below...
(config)#controller t1 1/1/1
(config-controller)#channel-group 0 timeslots  1-24
This command works with no issue!
Any help would be great!
Matt
Nagaraja Thanthry
Do you have enough DSP resources on the router to support channel-groups?
Please refer to the link below that kind of lists the DSP requirements for
different scenarios.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet0918
6a00800920f2.html
Hope this helps.
NT
Do I need DSPs for this WIC when it is used for PPP DATA only?
The NM does have 48 channels.
Is there a way to not allocate DSP resources for ports that don't require them?
Matt
