Inter VLAN routing and configuration.
ntmanjunath
I have a topology like this.Five L2 Switchs have the VLAN 1 and VLAN 2...Rquiremet is VLAN 1 and 2 shud be able to access the internet.
VLAN 1 shud Have access to all servers.
VLAN 2 Must have access to only Four servers (SQL,FTP,MAIL,HTTP) except E-Lab server.What could be the configuration in layer 3 switch and also the router 1841.please provide the complete configuration for this topology
12 Replies 12
motokdbr68
Use extended access list denying traffic from vlan 2 subnet to the ip of E-Lab server and permitting all other traffic. Apply this to both the i/fs connecting to switches, in incoming direction.
This should not allow vlan 2 traffic to e-lab server. Traffic to all other destinations should be reachable.
ACL will not effact vlan 1. Both vlans will be able to send traffic to the router and access internet. Also, intervlan communication will take place via L3 switch. Both the vlans interface have to be created on L3 Switch,which will act as g/w for the L2 switches for the respective vlans.
Rgds,
Dhiren Shah
Can you please explain with command for this topology? Any example
What vlan are the servers on ?
Where is the inter-vlan routing between vlan 1 & 2 done - is it on the 3560 switch or the 1841 router.
What are the IP address ranges for
vlan 1
vlan 2
server vlan (if different)
Jon
Given below is the sample config.. Try and see if it works.
All the config is to be done on the L3 Switch.
Intervlan routing will take place on L3 switch.
vlan 1: 192.168.1.0 255.255.255.0
vlan 2: 192.168.2.0 255.255.255.0
E-lab server ip: 192.168.5.1 255.255.255.0
interface vlan 1
no shut
interface vlan 2
no shut
ip address 192.168.2.1 255.255.255.0
ACL cmd:
access-list 101 deny ip 192.168.2.0 0.0.0.255 192.168.5.1 0.0.0.0
access-list 101 permit any
On i/f (f.e. fa0/0, fa0/1):
conf t
int fa0/0
ip access-group 101 in
int fa0/1
Thanks I got it
int fa0/0
int fa0/1
The above shown Ethernet ports are connected to trunk port? Or it's connected to E-Lab server
yes, they are trunk ports and not the port connecting to server.
__Dhiren
but what about NATing? where and how it will be implemented ?
In the above example the Access list has been implemeted on fa 0 and 1. I think these are L2 interfaces.. can we apply an IP ACL on a L 2 interface ?
No, ACL cant be implemented on l2 ports.. But, can be implemented on vlan i/f. So, in the config suggested earlier, i/f vlan 2(the concerned vlan for which access to e-lab router is to be restricted) has to be applied with ACL.
and what about NATing? where and how it will be implemented ?
In case of 2 ISPs how it will be implemented to loadbalance the traffic b/w the two links
OK.I understood.
The incoming traffic is deny from these two interface (f0/0 and f0/1)
The ACL configured L3 switch only
This is new implementation and nating is not configured till now.
jrjahangir
Here you not notify your IP address information about your Network.Give proper information then
i Can give your configuration.
Please contact me at: jrjahangir@yahoo.com
You can use any IP for understanding the concept. However I have assigned IP address for all devices. Please provide the configuration.
