Inter-Vlan Routing Issue
amatorjnr
I have this weird problem I'm facing on my network.
I have inherited an inter-vlan configuration with a layer 3 switch and everything works out fine.
Recently I had to add a new server to the network and I've noticed something weird.
All computers are on a different vlan and can communicate with each other and other servers.
example. PC = Vlan 2
Servers= vlan 3
New Server = vlan 4
everything works, pings go through all vlans.
BUT
After a while, both PC's and Servers on Vlan 2 and 3 can't ping New Server on Vlan 4.
Until
1. after i disconnect new server network cable and reconnect it,
2. or shutdown and renable port New Server is connected to
3. or i log in to the layer 3 switch and ping New Server
4. or I use a computer on vlan 4 to ping New Server.
AFter performing any of the options 1-4. All other host can ping New Server again for a while, then it stops.
I've noticed so far that until I'm continously pinging NEw Server, pings from all other vlans stop going through.
what could be the cause.
PS. New Server port = Access
Inter-vlan routing works
I've changed network cable twice
switch doesn't show any errors on interface
16 Replies 16
rasmus.elmholt
Level 7
Level 7
Can you share the configuration on all 3 ports and the 3 SVI's.
And show ip arp of the L3 switch when the problem occurs?
The PC and the 2 servers are all directly connected to the L3 Switch?
One thing I've realized just now is, all my Vlans have the same MAC address, so I suspect that's whats causing the issue.
Show log doesn't give any meaningful information.
And no, PC is not directly connected to the same switch as SERVER.
Vlan3 is up, line protocol is up , Autostate Enabled
Hardware is Ethernet SVI, address is 0008.e3ee.ec45 (bia 0008.e3ee.ec45)
Description: SERV_VLAN
Internet address is 172.16.13.1/24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Last input 00:00:12, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
IPv6 L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
IPv6 L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
625 packets input, 80755 bytes, 0 no buffer
Received 826 broadcasts (0 IP multicasts)
0 packets output, 0 bytes, 0 underruns
0 output errors, 1 interface resets
0 unknown protocol drops
Vlan2 is up, line protocol is up , Autostate Enabled
Description: FLEX
Internet address is 172.16.14.1/24
Last input 00:00:00, output never, output hang never
42486 packets input, 3963320 bytes, 0 no buffer
Received 97123 broadcasts (0 IP multicasts)
Vlan4 is up, line protocol is up , Autostate Enabled
Description: NEW_SERV
Internet address is 172.16.15.1/24
Last input 00:00:01, output never, output hang never
17002 packets input, 1763766 bytes, 0 no buffer
Received 31318 broadcasts (0 IP multicasts)
Hello ,
No , this is normal in Cisco implementation on many multillayer switch platforms and it is not a problem as they are in different L2 broadcast domains.
Rather I notice that the countes for L3 switches packet in and out are stuck at 0
Can you post a show version of your L3 switch ?
The above can be just a cosmetic issue the counters at 0 or a sign of an issue like CEF disabled on SVIs
To verify STP stability you can use
show spanning-tree detail | include topology
check also show ip arp for the new server IP address over time.
Hope to help
Giuseppe
This is the results of "show version"
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.09.00.E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 19-Jul-16 15:19 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG12
JDS-CORE-SWI uptime is 1 day, 13 hours, 29 minutes
Uptime for this control processor is 1 day, 13 hours, 31 minutes
System image file is "flash1:unknown"
Jawa Revision 3, Winter Revision 0x0.0x41
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-C4500X-16'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from PowerUp
13 Virtual Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Show spanning-tree | include topology outputs nothing
you need to add the detail keyword
It is a C4500X with IOS XE
Hope to help
Giuseppe
Number of topology changes 14 last change occurred 01:10:56 ago
Times: hold 1, topology change 35, notification 2
Timers: hello 0, topology change 0, notification 0, aging 300
Number of topology changes 859 last change occurred 00:00:20 ago
Timers: hello 0, topology change 14, notification 0, aging 300
Number of topology changes 700 last change occurred 00:00:20 ago
Number of topology changes 147 last change occurred 00:00:13 ago
Timers: hello 0, topology change 21, notification 0, aging 300
Number of topology changes 171 last change occurred 00:00:50 ago
Number of topology changes 314 last change occurred 00:01:08 ago
Number of topology changes 84 last change occurred 00:51:22 ago
Number of topology changes 125 last change occurred 00:20:18 ago
Number of topology changes 8 last change occurred 1d00h ago
Number of topology changes 118 last change occurred 00:04:49 ago
Number of topology changes 7 last change occurred 1d00h ago
Number of topology changes 14 last change occurred 19:34:19 ago
Hello ,
focus on the second and third VLAN in the list
use
show spanning-tree summary to know the list of VLANs
then for the second and the third that appear to be very active in STP
use
show spanning-tree vlan X detail
Look for the interface that caused the last topology change
This will help you find the problematic switch(es) and links
Hope to help
Giuseppe
there is broadcast storm I think .
Either that or just a loop in the network. Does show logging give any usefull information? MAC-Flapping?
Nope. show logging doesn't show any mac-flapping issue
I think so too but I can't find where its coming from cos all my troubleshooting leads to a dead end
Hello
On the switchport the server is connected - check it speed/duplex also make sure the port is defined as an access port and stp portfast is enabled.
On the server is it network card configuration correct - if it’s a windows server you can reset its network binding and api stack with the following command after which you need to reload the server and reapply it ip addressing.
start:run cmd
netsh interface ipv4 reset reset.log
netsh winsock reset reset.log
shutdown -r -f -t 5
Kind Regards
Paul
Yes, the port is set as an access port and stp portfast is enabled.
The server is also configured correctly, its not a windows server
Kevin Kilgore
Disconnect the new server and connect a laptop. See if it still occurs.
