Inter vlan routing problem
junaid haroon
i tried to archive the inter valn rotuing using layer 3 switch.i can ping every PC between different vlans.But i cannot ping router interface.Netwrok diagram is attached for your reference.
Here is configuration
Layer-3 switch
Building configuration...
Current configuration : 1439 bytes
version 12.2
hostname Switch
ip routing
ip ssh version 1
port-channel load-balance src-mac
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 10
interface FastEthernet0/4
switchport access vlan 20
interface FastEthernet0/5
interface FastEthernet0/6
no switchport
ip address 192.168.40.253 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.254 255.255.255.0
interface Vlan20
ip address 192.168.20.254 255.255.255.0
interface Vlan30
ip address 192.168.30.254 255.255.255.0
router rip
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.40.254
line con 0
line vty 0 4
login
end
My layer 2 Switch configuration
Current configuration : 967 bytes
version 12.1
hostname Switch
switchport access vlan 30
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
please help me out
18 Replies 18
Hi cadet
I define the managment vlan on core switch and layer 2 switch.But its not working
managment vlan Ip on layer 3 switch  192.168.50.253
management vlan on layer 2 switch   192.168.50.254     ip-default gateway  192.168.50.253
Here is layer 3 switch.
Current configuration : 1541 bytes
version 12.2
hostname Switch
ip routing
ip ssh version 1
no switchport
duplex auto
speed auto
switchport access vlan 50
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
interface Vlan30
interface Vlan50
ip address 192.168.50.253 255.255.255.0
router rip
ip classless
line con 0
line vty 0 4
password test
login
end
Layer 2 switch conf
Current configuration : 1258 bytes
version 12.1
hostname Switch
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
interface Vlan30
interface Vlan50
ip address 192.168.50.254 255.255.255.0
ip default-gateway 192.168.50.253
line con 0
line vty 0 4
password test
login
line vty 5 15
login
end
Switch#
Hi Junaid,
What model of L2 switch you are having?  You have created multiple SVI interface on this switch hence i hope it would be able to do routing as well.On the switch you are calling as "Layer 2 switch" add below line and see if that helps
ip route 0.0.0.0 0.0.0.0 192.168.50.253
If this is not working then please share below output from the L2 switch.
show ip int brief
show ip route
Hope that helps
Regrads
Najaf
I am using 2950 as layer 2 switch.Above command is not working in layer2 switch.below is output.Interface vlan 50showing me down hoever i issue no shut down command still down
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#ip route 0.0.0.0 0.0.0.0 192.168.50.253
% Invalid input detected at '^' marker.
Switch#sh ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/1        unassigned      YES manual up                    up
FastEthernet0/2        unassigned      YES manual up                    up
FastEthernet0/3        unassigned      YES manual up                    up
FastEthernet0/4        unassigned      YES manual up                    up
FastEthernet0/5        unassigned      YES manual down                  down
FastEthernet0/6        unassigned      YES manual down                  down
FastEthernet0/7        unassigned      YES manual down                  down
FastEthernet0/8        unassigned      YES manual down                  down
FastEthernet0/9        unassigned      YES manual down                  down
FastEthernet0/10       unassigned      YES manual down                  down
FastEthernet0/11       unassigned      YES manual down                  down
FastEthernet0/12       unassigned      YES manual down                  down
FastEthernet0/13       unassigned      YES manual down                  down
FastEthernet0/14       unassigned      YES manual down                  down
FastEthernet0/15       unassigned      YES manual down                  down
FastEthernet0/16       unassigned      YES manual down                  down
FastEthernet0/17       unassigned      YES manual down                  down
FastEthernet0/18       unassigned      YES manual down                  down
FastEthernet0/19       unassigned      YES manual down                  down
FastEthernet0/20       unassigned      YES manual down                  down
FastEthernet0/21       unassigned      YES manual down                  down
FastEthernet0/22       unassigned      YES manual down                  down
FastEthernet0/23       unassigned      YES manual down                  down
FastEthernet0/24       unassigned      YES manual down                  down
Vlan1                  unassigned      YES manual administratively down down
Vlan10                 192.168.10.254  YES manual up                    up
Vlan20                 192.168.20.254  YES manual up                    up
Vlan30                 192.168.30.254  YES manual up                    up
Vlan50                 192.168.50.254  YES manual down                  down
Switch#
Ok fine..
Forget about my previous post then.
Have you created a L2 vlan for vlan 50 here? If not try
config terminal
vlan 50
name managment
exit
After this if this is still not working could you please share the output of below command from this L2 switch.
sh ip int brief
sh vlan
sh int trunk
sh cdp nei details
Najaf
