High CPU load on ASR1002
Iulian Vaideanu
Level 4
Level 4
We have several ASR1002 and ASR1004 devices used as PPPoE concentrators.  One of them, recently deployed, seems to be a bit more loaded than it should be (compared to others of similar configurations).  The platform's specs are ASR1002 / RP1 / ESP10 / SIP10 running IOS XE 3.9.1S, and given ~2700 simultaneous PPPoE sessions and 850Mbps / 500 Mbps (up / down) of traffic, I get the following:
#show platform software status control-processor brief
Load Average
Slot  Status  1-Min  5-Min 15-Min
  RP0 Healthy   0.30   0.42   0.43
ESP0 Healthy   0.22   0.26   0.16
SIP0 Healthy   0.02   0.01   0.00
Memory (kB)
Slot  Status    Total     Used (Pct)     Free (Pct) Committed (Pct)
  RP0 Healthy  3874516  1830528 (47%)  2043988 (53%)   2433452 (63%)
ESP0 Healthy  2009440   646056 (32%)  1363384 (68%)    449160 (22%)
SIP0 Healthy   449316   296768 (66%)   152548 (34%)    290272 (65%)
CPU Utilization
Slot  CPU   User System   Nice   Idle    IRQ   SIRQ IOwait
  RP0    0  27.34   8.28   0.00  62.87   1.19   0.29   0.00
ESP0    0  15.38  16.78   0.00  67.33   0.09   0.39   0.00
SIP0    0   2.30   1.10   0.00  96.59   0.00   0.00   0.00
On an identical platform (hardware-wise) running IOS XE 3.4.0S, I get lower CPU load values with much more traffic (~4500 PPPoE sessions and 1.6Gbps / 1.3Gbps of traffic):
Load Average
  RP0 Healthy   0.82   0.85   0.84
ESP0 Healthy   1.70   1.71   1.66
SIP0 Healthy   0.00   0.00   0.00
Memory (kB)
  RP0 Healthy  3874968  2083852 (54%)  1791116 (46%)   2663188 (69%)
ESP0 Healthy  2009892   766344 (38%)  1243548 (62%)    618688 (31%)
SIP0 Healthy   449768   328112 (73%)   121656 (27%)    360644 (80%)
CPU Utilization
  RP0    0  24.75   5.28   0.00  68.76   0.79   0.39   0.00
ESP0    0  16.31   5.90   0.00  77.27   0.10   0.40   0.00
SIP0    0   0.70   0.60   0.00  98.50   0.00   0.20   0.00
What might be related to the CPU load issue is that in the logs of the problematic ASR there are a lot of "%IOSXE_INFRA-3-PUNT_ADDR_RES_ENCAP_ERR: Punted address resolution packet with unknown encap PPP" entries.  Another possibly relevant piece of info is that the problematic ASR uses port-channelled "downlink" GbE interfaces (with manual (Vlan-based) load-balancing).
The questions are:  could the use of port-channels affect CPU load on ASR1K?  what could be the cause of those log entries?  what else (IOS commands) can I use to debug this CPU load issue further?
Many  thanks in advance.
Iulian Vaideanu
Level 4
Level 4
In a Linux session on the RP, "top" show the outputs below (sorted by CPU time - first one is taken from the problematic ASR, second one from the other ASR, used for comparison).  It may be just a coincidence, but on the abnormally loaded ASR the "hman" process takes quite a lot of CPU time...  what exactly does the "Host Manager" process do?
1st (problematic):
top - 16:54:00 up 6 days, 10:07,  0 users,  load average: 1.15, 1.08, 1.02
Tasks: 149 total,   1 running, 148 sleeping,   0 stopped,   0 zombie
Cpu(s): 40.5%us, 31.9%sy,  0.0%ni, 25.9%id,  0.0%wa,  1.2%hi,  0.5%si,  0.0%st
Mem:   3874516k total,  1843064k used,  2031452k free,   152376k buffers
Swap:        0k total,        0k used,        0k free,   969184k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+    TIME COMMAND
29314 root      20   0 1949m 611m 176m S 31.7 16.2   2391:21  39,51 linux_iosd-imag
28162 root      20   0 20640 7196 4704 S  1.6  0.2 132:20.19 132:20 hman
27377 root      20   0  159m 100m  93m S  1.0  2.7  78:41.58  78:41 fman_rp
26551 root      20   0 36420  13m  10m S  0.7  0.4  71:03.11  71:03 cmand
16924 root      15  -5     0    0    0 S  0.6  0.0  46:21.40  46:21 lsmpi-xmit
16925 root      15  -5     0    0    0 S  0.6  0.0  44:53.33  44:53 lsmpi-rx
    4 root     -50   0     0    0    0 S  0.5  0.0  29:37.12  29:37 sirq-timer/0
    6 root     -50   0     0    0    0 S  0.3  0.0  28:38.28  28:38 sirq-net-rx/0
   12 root     -50   0     0    0    0 S  0.3  0.0  24:46.83  24:46 sirq-rcu/0
26099 root      20   0  4944 3220 1252 S  1.2  0.1  22:39.71  22:39 btrace_rotate.s
32212 root      20   0  122m 111m 6704 S  0.1  2.9   9:25.64   9:25 smand
26889 root      20   0 24720 7620 5124 S  0.0  0.2   5:40.07   5:40 emd
28436 root      20   0 29680  15m  13m S  0.0  0.4   4:05.69   4:05 imand
30341 root      20   0 18712  948  724 S  0.0  0.0   3:22.02   3:22 pcscd
16923 root      15  -5     0    0    0 S  0.0  0.0   2:36.59   2:36 lsmpi-refill
32611 root      20   0  4100 2308 1192 S  0.0  0.1   1:53.54   1:53 sort_files_by_i
2nd (ok):
top - 16:51:20 up 271 days, 11:10,  0 users,  load average: 1.28, 1.04, 0.76
Tasks: 132 total,   5 running, 127 sleeping,   0 stopped,   0 zombie
Cpu(s): 28.7%us,  9.6%sy,  0.0%ni, 60.7%id,  0.0%wa,  0.5%hi,  0.5%si,  0.0%st
Mem:   3874968k total,  2090688k used,  1784280k free,   133848k buffers
Swap:        0k total,        0k used,        0k free,  1229736k cached
26121 root      20   0 1917m 585m 145m R 69.8 15.5  30640:29 510,40 linux_iosd-imag
25349 root      20   0 26820  14m  13m S  1.0  0.4   3499:32  58,19 imand
23360 root      20   0 28476  12m 8980 R  0.8  0.3   2639:35  43,59 cmand
14988 root      15  -5     0    0    0 R  0.3  0.0   1698:23  28,18 lsmpi-rx
24216 root      20   0  158m 111m 105m S  1.0  2.9   1570:34  26,10 fman_rp
14987 root      15  -5     0    0    0 S  0.4  0.0   1099:26  18,19 lsmpi-xmit
24935 root      20   0 16716 5932 4216 S  0.2  0.2 523:52.12 523:52 hman
23041 root      20   0  4960 3264 1252 S  0.5  0.1 507:25.29 507:25 btrace_rotate.s
28331 root      20   0  101m  91m 6468 S  0.1  2.4 194:33.48 194:33 smand
23708 root      20   0 19716 6556 4080 S  0.0  0.2 194:29.48 194:29 emd
28712 root      20   0  4208 2436 1184 S  0.0  0.1 129:20.18 129:20 sort_files_by_i
  315 root      20   0  5048 3336 1244 S  0.1  0.1  53:34.76  53:34 chasync.sh
14734 root      20   0  4460 2816 1308 S  0.1  0.1  21:53.70  21:53 reflector.sh
14986 root      15  -5     0    0    0 R  0.0  0.0  20:38.17  20:38 lsmpi-refill
Call admission control exist in your configuration?
If not, please try these (before reload the box):
call admission new-model
call admission limit 700
call admission cpu-limit 70
call admission pppoe 10 1
call admission pppoa 10 1
call admission vpdn 10 1
call admission ip 10 1
In our (similar) case this help.
