Inter vlan routing problem
junaid haroon
Level 3
Level 3
i tried to archive the inter valn rotuing using layer 3 switch.i can ping every PC between different vlans.But i cannot ping router interface.Netwrok diagram is attached for your reference.
Here is configuration
Layer-3 switch
Building configuration...
Current configuration : 1439 bytes
version 12.2
hostname Switch
ip routing
ip ssh version 1
port-channel load-balance src-mac
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 10
interface FastEthernet0/4
switchport access vlan 20
interface FastEthernet0/5
interface FastEthernet0/6
no switchport
ip address 192.168.40.253 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.254 255.255.255.0
interface Vlan20
ip address 192.168.20.254 255.255.255.0
interface Vlan30
ip address 192.168.30.254 255.255.255.0
router rip
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.40.254
line con 0
line vty 0 4
login
end
My layer 2 Switch configuration
Current configuration : 967 bytes
version 12.1
hostname Switch
switchport access vlan 30
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
please help me out
18 Replies 18
kcnajaf
Level 11
Level 11
HI Junaid,
Not sure if i got your problem right?
You have mentioned that "I can ping every PC between different vlans" that mean your able to ping from on pc to other pc on different vlans? If that is the case then inter-vlan routing is working right?
You have trouble in pinging only the router interface from the PC? Is that right? If so can you please tel from which PC your trying to ping which ip address on the multi-layer switch?
Also have you enabled routing gloabally with command "ip routing" ?
Najaf
Paul M1
Level 4
Level 4
Display SH IP ROUTE on the L3 switch?
Jan Hrnko
Level 9
Level 9
Hi Junaid,
The problem is most probably at the Router0. Does it have ip route back to these VLANs? Or does it at least have default route configured, pointing at the Switch0?
Try to do traceroute from PC, see if you get any reply from Router0. Check Router0's routing table, if it has records for addresses from which you are pinging:
Router0#show ip route [IP_ADDRESS_OF_THE_COMPUTER_FROM_WHICH_YOU_ARE_PINGING]
If you get output like this: % Network not in table add appropriate routes (configure static or dynamic routing).
I wouldn't worry about ip routing command though, the running-config you have provided clearly states that it is enabled.
Best regards,
Jan
Hi Jan,
Here the output of Router0#show ip route command on router0
Router#sh ip route 192.168.30.2
Router#
Jan can you please guide me how i define a route on router.And the default on layer 3 switch is already added.
looking forward for your reply
ip route 192.168.30.0 255.255.255.0 192.168.40.253
Alain
Hi cadet,
Do you saw my diagram after adding this route my traffic come back to lan.I want to out my traffic from router.and make a things that users can also ping router
if you want to ping the router interface 192.168.40.254 from the PCs then you must give a route for each vlan subnet on the router,each pointing towards the L3 routeds port of the L3 switch doing the interVlan routing.
What I gave you is one of these static routes.
Alain
Hi cadet,
Got it and Thanks.I have one more issue on layer 2 switch i caan't ping any vlan interface??
as Alain said, you must configure static routes for every vlan, or you can define default route (which will forward any packet to the swtich, for which the router doesn't have a better route). You have that already on your switch but lacking on router. Default route will take care of everything in your case. I think that you can configure it this way in packet tracer:
Router0(config)#ip route 0.0.0.0 0.0.0.0 192.168.40.253
From which host/switch/router, with what source IP address are you pinging which vlan interface? Please, post also configs of these devices or upload your pkt file, so we can help you out.
Best regards,
Jan
You must have a  management interface Vlan with an ip address and ip default-gateway x.x.x.x where x.x.x is the vlan interface in this management vlan on the layer 3 switch.
Alain
Hi jan,
I did't little amendent its starts pinging.
Now I want 1 managment vlan from which i telnet every switch how i do this???
Here is layer 2 switch configuration
Switch#sh run
urrent configuration : 1147 bytes
version 12.1
hostname Switch
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
interface Vlan30
line con 0
line vty 0 4
login
line vty 5 15
login
end
just create one VLAN on all switches ,for example vlan 99 and configure a SVI(vlan interface) with an ip address for this vlan on all switches then on the l2 switches configure ip default-gateway x.x.x.x where x.x.x.x is the vlan interface for management IP.On your router if you didn't configure a default route pointing towards the l3 switch then create a static route for this Vlan subnet.
Alain
Hi cadet alain
What should be the default gateway for management vlan??
the ip address of the management vlan interface on the core switch.
Alain
