Inter-vlan Routing Question
rkeeran
Hello All
I am trying to set up inter-vlan routing without a router. I have a Catalyst 3560 that has 5 vlans. This switch Is connected to a ISP Modem. Intervlan routing is set up on the switch but I am stuck. I am unable to browse the internet from any of the vlans. I am able to ping 8.8.8.8 from the switch but not from the vlans. If there is a router present I can use NATing to fix this but trying to see if it is possible to do it without the need of a router.
Building configuration...
Current configuration : 4540 bytes
version 12.2
no service pad
hostname TLab-Edge
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
vtp domain TestLab
vtp mode transparent
ip subnet-zero
ip routing
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp excluded-address 192.168.30.1 192.168.30.10
ip dhcp excluded-address 192.168.40.1 192.168.40.10
ip dhcp excluded-address 192.168.50.1 192.168.50.10
ip dhcp pool CCTV
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 8.8.8.8 8.8.4.4
ip dhcp pool DATA
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
ip dhcp pool VOICE
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.1
ip dhcp pool TV-WIFI
   network 192.168.40.0 255.255.255.0
   default-router 192.168.40.1
ip dhcp pool POS_ATM
   network 192.168.50.0 255.255.255.0
   default-router 192.168.50.1
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10
name CCTV
vlan 20
name DATA
vlan 30
name VOICE
vlan 40
name TV-WIFI
vlan 50
name POS-ATM
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
interface GigabitEthernet0/1
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
switchport access vlan 20
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
switchport access vlan 30
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
switchport access vlan 40
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
switchport access vlan 50
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
no switchport
ip address dhcp
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface TenGigabitEthernet0/1
interface TenGigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
interface Vlan30
ip address 192.168.30.1 255.255.255.0
interface Vlan40
ip address 192.168.40.1 255.255.255.0
interface Vlan50
ip address 192.168.50.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip http server
control-plane
line con 0
line vty 5 15
end
2 Accepted Solutions
the short answer is: you need the router. The switch does not do NAT. You are better off doing a "router-on-a-stick" setup. If you don;t know how to use subinterfaces on the router, post the router config as well, so we can help you with the details...
11 Replies 11
Hi Georg
Thanks for the rapid response. I have a Cisco 2621xm and when I set up router on a stick, speeds are below 30 Mbps when I get connectivity. Is there a way to fine tune the performance of the network if router on a stick is set up?
the 2621XM is end of sale as of 2007, so you obviously have an ancient device there. Not sure how much that can be tuned, post the running config of the 2621XM. But actually, to be honest I think the router will be the bottleneck no matter what.
Hi Georg
I have setup up Router on a stick on my set up at home. Please see configs attached
See attachment for performance of a 2621XM.
Hi Joseph
Thanks for the heads up. What can I expect from a Cisco 2811 router?
the 2811 is end of sale as of 2011. It won't be a big improvement.
What is your budget ? You might be better of just buying, depending on what you are willing to spend, a Cisco ISR 1111 (around 700 dollars) or just a 'cheap' ISP modem (around 100 to 200 dollars).
Hi Georg
Its for a small office space. Service provider is potentially going install a Hub 2000/3000 modem. Client wants to reduce costs as much as possible. Trying to exhaust my options before going with the only option available.
See attachments.
Thanks Joseph!
I really appreciate it. I have a bit more to reconsider. Thanks
Hello
As stated by @Georg Pauwen you will need a router for the network translation and also quite a good scalable one to accommodate the amount of users you may have.
I would personally look into meraki soho rtrs, however review the following selector to provide you with some idea on what would be applicable. -here
Kind Regards
Paul
