ACL. OSPF
Geless
Hello
I need to configure the ACL on the router so that the routing table is not updated.
5 Replies 5
can you more clarify your request.
I have four routers, and on one of them I need to configure the access control list so that the routing table in it remains unchanged.
Harold Ritter
Hi @Geless ,
You can use ospf inbound filtering feature to do this. Please refer to the following documentation to learn how to use this feature.
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/iproute_ospf/configuration/xe-16/iro-xe-16-book/iro-inbound.html.xml
Hello
Are these rtrs in the same ospf area sharing the same topology database?
Regards keeping the route table the same do you mean you would like to accept the same current routes you are receiving and filter all future routes, or you would like to filter all routes and have just a default?
If you could elaborate on exactly what you want to filter and how the these ospf rtrs are connected would depend on how the filtering is applied.
Kind Regards
Paul
Either filter LSA or
 ospf flood-reduction feature.
