inter vlan routing stoping
we need config on WS-C3560G-24TS-S inter vlan communication stoping as per attached document.
twhittle1
Hi Raja,
It is possible to control access between VLANs with Access Control Lists (ACLs), either normal ACLs or VLAN ACLs (VACLs) depending on how you have your network configured.
Below is a link to the configuration guide for Cataylyst 3560s showing you how to create these:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_58_se/configuration/guide/swacl.html
If you get stuck I advise more specific configuration commands but I'd need to know a little more information on how the swicth is configured (a show run would do it).
Tom
twhittle1
Hi Raja,
Tom
