09-12-2019 01:41 AM
Hi everyone,
I want to make multicasting with multi Vlans.
I have one switch C3560G-48TS / 12.2(35)SE5.
I build two vlans vlan2 and vlan3.
and they has address like this,
vlan2 10.10.10.254 / 255.255.255.0
vlan3 20.20.20.254 / 255.255.255.0
and I turn on ip route option.
So I success ping test with two host each other.
but When I send multicast packet with Multicast group ip 239.100.100.100 and TTL value 32.
Multicast packet can't reach to any host.
I need your help.
Thank you!
09-12-2019 03:58 AM
Hello Paul,
IPv4 multicast routing needs additional commands to work:
a) ip multicast-routing in global config this makes the device a mcast router
B) on each SVI add
int vlan 2
ip pim sparse-dense mode
exit
int vlan 3
exit
Create a loopback interface to make the switch an RP
int loop0
ip address 10.255.255.1 255.255.255.255
ip pim sparse-mode
exit
ip pim rp 10.255.255.1
Note:
if you have multiple devices the loop0 has to be created only on one f them and it needs to be advertised in a unicast routing protocol like OSPF or EIGRP.
Enabling PIM on an SVI enables also IGMP (version 2 by default)
IGMP deals with receivers (PCs)
PIM is needed between multicast capable routers on all links between them
Hope to help
Giuseppe
Hope to help
Giuseppe
09-12-2019 04:07 AM
09-15-2019 06:50 PM
If I can't find ip multicast-routing command in global config.
How can I use multicasting with my switch?
Need I update IOS version to latest or other command exist for IOS old version?
09-12-2019 04:01 AM
Hello
You will need to enable ip multicasting and apply pim to the svi of the L3 switch
conf t
ip multicast-routing distributed
int vlan xx
ip pim sparse-dense-mode
exit
09-15-2019 06:51 PM
09-16-2019 12:58 AM
Hello
What switch/ios are you running?
09-16-2019 03:34 AM
09-16-2019 03:51 AM - edited 09-16-2019 04:04 AM
as far as I recall, IP Multicast routing is supported only on Catalyst 3560-CX switches...
Either that, or you need the IP Services image. Which one do you have ?
Best to post the output of 'show license'...
09-16-2019 04:00 AM
Hello
That make/model and ios feature should support MC routing.
can you post what message you receive when you try to enable MC rorutingy?
Also show the output of the following:
sh sdm prefer
09-16-2019 04:37 AM
09-16-2019 11:48 AM
09-16-2019 12:49 PM
Hello Paul,
post
show version
show version | inc image
As already noted you are likely running a software image that allows only to use IGMP snooping but not full multicast routing.
With these old images the image name tells the feature set ( it is part of the name).
Alternatively you may need to change the sdm template to another type (this requires reload to take effect) as you have a desktop SDM template. You may need to change it to another type more routing oriented ( I don't remember the exact name for your switch)
Hope to help
Giuseppe
09-17-2019 06:25 AM
Thank you for everyone.
Now I know why couldn't using multicasting with my switch.
So what is best way to use multicasting?
If should i reload or update image is not good for me.
Because my other cisco switch almost 10 more is working in client office.
They doesn't like change and afraid lost configuration.
