Interface ADSL like backup link
Wilbert Paredes
Hi, i will going to buy a router 2911 but i want know if support a interface ADSL modulo like backup in case that my primary link WAN Ethernet down and up the adsl link with a module HWIC ADSL pots. Thanks
Hi Wilbert,
     Sure you can do that. The following link is what types of interface are supported for ISR G2 Routers.
     Ref: http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
     To do a backup link, you have to configure on the router. There are many ways to accomplish this.
HTH,
Toshi
