SNTP no such command on C1941
ryanhoibm
Level 2
Level 2
Hi All,
I have two C1941.The first C1941 does not support SNTP but the second C1941 supports SNTP.
The only difference which I can spot is their license. The first C1941 does not have security license but the second C1941 has.
Does anyone has any clue?
What is the URL that has info on what IOS commands are supported on IPbase license, sec license..etc
First C1941
C1941_1(config)#do sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 16:26 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
C1941_1 uptime is 13 minutes
System returned to ROM by reload
System image file is "flash0:c1900-universalk9-mz.SPA.150-1.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco CISCO1941/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID xxx
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 ISDN Basic Rate interface
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1941/K9          xxxx
Technology Package License Information for Module:'c1900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
data          None          None          None
C1941_1(config)#sn
C1941_1(config)#sn?
snap  snmp  snmp-server
Second C1941
C1941_2#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 24-Mar-11 13:55 by prod_rel_team
C1941_2 uptime is 1 hour, 30 minutes
System returned to ROM by reload at 16:12:44 SIN Mon Apr 25 2011
System image file is "flash:c1900-universalk9-mz.SPA.151-4.M.bin"
[email protected].
Cisco CISCO1941/K9 (revision 1.0) with 2506688K/114688K bytes of memory.
Processor board ID yyy
1 terminal line
1 Virtual Private Network (VPN) Module
4099032K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1941/K9          yyy
security      securityk9    Permanent     securityk9
data          None          None          None
C1941_2#$                                                     conf t
Enter configuration commands, one per line.  End with CNTL/Z.
C1941_2(config)#sn?
snap  snmp  snmp-server  sntp
5 Replies 5
paolo bevilacqua
In case you haven't noticed, your 2nd unit is running newer software.
Sorry I have forgotten to mention that even with the same IOS, I am able to configure sntp. Only that particular chassis without Sec license can't. Any idea where can I check on the supported IOS commands for different license?
You can check the feature navigator, but it requires a paid support contract, and sometime is not 100% accurate.
Leo Laohoo
Why not use NTP instead?
I am quite sure its because of the security license because I have another router C3925, which does not have the security license and it does not have SNTP as well hehe
Yupe I will use NTP instead.
