Interface configuration for Cat3550 to Cisco828
m.saufi
All,
Appreciate if anyone can suggest a proper interface configuration in Cat3550 when connected to a Cisco828(which is connected to another 828 via a pair of copper cable, something like extended the LAN from Cat3550). Thanks for any responses.
jackyoung
Level 6
Level 6
Please advise the detail requirement then we can help. If it is only a layer 2 connection at the 3550. There is no specific configuration required. If you want some features at 3550, please advise.
Hope this helps.
Layer 2 all the way from the end 828<-->828<-->Cat3550(DHCP server sits here). I'm referring to Cat3550 fastethernet interface configuration that connects to 828 and was thinking whether something like below can help:
switchport mode access
spanning-tree portfast disable
speed 10
duplex half
no shut
Thanks.
Modular multiservice high-density access router
  Enable higher levels of application and service integration in enterprise branch offices in a
 Small form factor
 Wide variety of interface support, high-den
 Sity analog and digital, voice, Cisco IOS
 Firewall/IDS and VPN, Fractional and channelized T1/E1, T3/E3, DS3, E3 and OC-3 ATM,
Ethernet, Gigabit Ethernet and DSL.
 Shares WAN interface cards (WICs), Voice Interface Cards (VICs), and Network Module
 Default configuration in cisco router 828
 8 MB On board flash
16MB On board DRAM + 4MB, 8MB or
16MB DIMM module
 Companies who Cisco IOS-based networks who want to add telecommuters
 VARs who are familiar with Cisco IOS software and want to profitably service small office customers
 Ethernet LAN ports and variety of WAN connectivity, i
 ncluding: ISDN BRI, Frame Relay, ADSL, G.SHDSL,
 async dialup.
jkilleda
Level 3
Level 3
Hello Morshidi,
Please try using the below config commands for the connection from cat3550 to cisco828
Switch (config-if) # switchport trunk encapsulation  dot1q
Switch (config-if) # switchport mode trunk
