Connecting OSPF to eBGP
Ardhiannash
i have some problem with connecting OSPF to eBGP
im using OSPF to connect the VLAN 10 and 20 to R1 but im unable to ping to the other AS.
after i configure the eBGP, R1 able to ping 192.168.30.1 on R3 but unable to ping 192.168.30.2 on R4.
here's my configuration.
R2
router ospf 10
network 10.10.11.0 0.0.0.255 area 0
network 10.10.12.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.3 area 0
R1
router ospf 10
router bgp 100
neighbor 192.168.10.2 remote-as 200
network 192.168.10.0 mask 255.255.255.252
neighbor 192.168.10.2 next-hop-self
R3
Router ospf 10
network 192.168.30.0 0.0.0.3 area 0
router bgp 200
neighbor 192.168.10.1 remote-as 100
neighbor 192.168.10.1 next-hop-self
since GNS3 doesn't support inter-vlan routing, im using OSPF. When i look at the routing table
on R1 it's said that network 192.168.30.0 have no Next-hop address (direct)
does anyone have solution for this? im new at this and cant figure it out on my own.
Try:
!! R2
router ospf 10
  redistribute bgp 100 subnets
!! R3
router ospf 20
  redistribute bgp 200 subnets
Then share the output of sh ip route from R2 and R3.
Seb Rupik
Hi there,
You need to redistribute the OSPF routes in the BGP process and vice versa. This will advertise the internal routes to the BGP peer.
At its simplest, this should work:
!! R2
! router ospf 10 redistribute bgp 100 router bgp 100 redistribute ospf 10 ! !! R3 ! router ospf 20 redistribute bgp 200 router bgp 200 refistribute ospf 20 !
cheers,
Seb.
Hi, thanks for your reply
i tried to redistribute the OSPF and it said:
R3(config)#router ospf 20
R3(config-router)#redistribute bgp 200
% Only classful networks will be redistributed
R3(config-router)#
and im still unable to ping from R1 to PC4.
im using OSPF and eBGP on R1 and R3.
i check the OSPF and there is nothing wrong with it.
R1 able to ping PC2 & PC1
R3 able to ping PC3 & PC4.
do you have any other suggestion?
Try:
!! R2
router ospf 10
!! R3
router ospf 20
Thanks you for the solution, its work perfectly.
