04-25-2023
07:28 PM
- last edited on
04-26-2023
03:21 AM
by
Translator
Hi everyone,
I am trying to set up an eigrp lab on EVE-NG but on one router every time I set up the interface and no shut it I get the following messages:
*Apr 26 02:14:34.500: %LINK-5-CHANGED: Interface Ethernet0/0, changed state to administratively down
R8(config-if)#
*Apr 26 02:14:37.013: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
*Apr 26 02:14:38.013: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to up
R8(config-if)#
*Apr 26 02:14:47.017: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to down
*Apr 26 02:14:48.017: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to down
This is my configuration:
R8#show run int e0/0
Building configuration...
Current configuration : 79 bytes
interface Ethernet0/0
ip address 10.10.10.8 255.255.255.0
duplex auto
end
R8#show interface e0/0
Ethernet0/0 is down, line protocol is down
Hardware is AmdP2, address is aabb.cc00.0800 (bia aabb.cc00.0800)
Internet address is 10.10.10.8/24
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto Speed, media type is unknown media type
input flow-control is off, output flow-control is unsupported
Last input 00:02:03, output 00:02:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1 packets input, 364 bytes, 0 no buffer
Received 1 broadcasts (0 IP multicasts)
29 packets output, 7675 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Whenever I no shut the interface, I am able to ping myself for like 5 seconds then the interface goes down again. Not sure how to go about fixing this issue any help would be greatly appreciated.
Solved! Go to Solution.
04-25-2023 08:14 PM
Try rebooting the device. Sometimes those virtualized instances are glitchy. If that does not work delete R8 and replace it with a new Router in the EVE-NG lab
Hope that helps
-David
04-25-2023 08:14 PM
Hope that helps
-David
04-25-2023 08:21 PM
Hi David,
Thanks for getting back to me I actually already wiped the router and was experiencing the same issues, so I replaced it with a new router (same version though) and was still experiencing the same issue. I will try that again and maybe switch to a different version of the router and will let you know if that works.
Thanks again,
Al-Hussein
04-25-2023 08:26 PM
Ok. If that doesn't work save configurations and restart the EVE-NG server. I don't see anything in the config that would make it shut down unless you didn't have an active link connecting that interface to another device.
04-25-2023 08:31 PM
Ok, perfect If it doesn't work, I will definitely try that. And yes, I do have a device connecting to this device with an active link. I should have mentioned that 🙂
04-25-2023 08:57 PM
Switching to a Cisco vIOS router worked for me thanks again for your help David!
