Interface error
Just Kennie
Please what is the possible cause and solution of this interface error.
BB1#show int fa0/1
FastEthernet0/1 is up, line protocol is up
  Hardware is Gt96k FE, address is 0007.0e3c.f957 (bia 0007.0e3c.f957)
  Description: *****WAN CONNECTION *****
  Internet address is xx.xx.xx.xx/29
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/4/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 277000 bits/sec, 120 packets/sec
  5 minute output rate 149000 bits/sec, 140 packets/sec
     2615122 packets input, 739484174 bytes
     Received 957 broadcasts, 246 runts, 0 giants, 0 throttles
     5994 input errors, 5994 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     2843074 packets output, 371490795 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Edison Ortiz
Leo Laohoo
The command "sh controller ethernet F0/1" will give you a detailed information about the line errors.
paolo bevilacqua
Chances are, the other device is set to half-duplex.
