Interface in/outbound conversation is not show on the network analyzer
Pafum
the net- analysis -Ingress/egress is configure but the the interface in/out bound conversation is not showed on the network traffic analyzer (LiveNX). Need help pls below is the flow config summary
cort01-ipv6#sh run | sec flow
flow record NET-ANALYSIS-INGRESS
match flow direction
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface output
collect ipv4 ttl minimum
collect ipv4 ttl maximum
collect transport tcp flags
collect timestamp sys-uptime first
collect timestamp sys-uptime last
collect application name
collect counter bytes
collect counter packets
collect flow sampler
collect ipv4 destination mask
collect ipv4 dscp
collect ipv4 id
collect ipv4 source mask
collect ipv4 source prefix
collect routing destination as
collect routing next-hop address ipv4
collect routing source as
flow record NET-ANALYSIS-EGRESS
match ipv4 tos
match ipv4 protocol
match interface input
collect interface output
collect ipv4 dscp
collect ipv4 id
flow record FLOW-RECORD-1
collect interface input
flow exporter FLOW-EXPORTER-LIVEACTION
destination 10.238.13.116 vrf VAVRF
source Loopback0
transport udp 2055
export-protocol ipfix
option interface-table
option vrf-table
option application-table
option c3pl-class-table
option c3pl-policy-table
flow exporter FLOW-EXPORTER-EFFICIENCY-REPORT-LAB
destination 10.252.1.5 vrf VAVRF
source Loopback0
transport udp 2055
option vrf-table
flow monitor NET-ANALYSIS-EGRESS
cache timeout inactive 10
cache timeout active 60
flow monitor NET-ANALYSIS-INGRESS
ip flow monitor NET-ANALYSIS-EGRESS output
ip flow monitor NET-ANALYSIS-INGRESS output
ip flow monitor NET-ANALYSIS-INGRESS input
10 Replies 10
balaji.bandi
source Loopback0
as per the config you using VRF and source as loopback0  - loopback belong to vrf ?
what is the output :
show ip flow export
show ip flow interface
BB
yes I got that
show run | sec flow export
source Loopback0
still cannot able to access.
I just checked flow record NET-ANALYSIS-INGRESS
It missing a statement " collect interface input" and match interface out is present. can this be and issue? if so how to resolve it
source Loopback0  - is this belong to VRF
show run interface loopback0 ?
here is working config :
https://www.balajibandi.com/?p=1383
BB
Again I tried to config the missing statement on the flow record NET-ANALYSIS-INGRESS ( collect interface input) but it given me this statement -" % Flow Record: Failed to field add: Object is in use".  how can I resolve it
if the flow monitor is used in the interface you need to remove it before configuring : (no flow monitor and no flow record no flow export)
You must use the no ip flow monitor command to remove a flow monitor from all of the interfaces to which you have applied it before you can modify the parameters for the record command on the flow monitor.
BB
cort02-ipv6(config)#flow record NET-ANALYSIS-INGRESS
cort02-ipv6(config-flow-record)#collect interface input
this is the issue I am facing right now. can I get some help to fix this
% Flow Record: Failed to field add: Object is in use.
Example :
config t
interface x/x
no ip flow monitor NET-ANALYSIS-INGRESS input
no ip flow monitor NET-ANALYSIS-EGRESS output
BB
still having the same issue. just take off all ip flow monitor, try again still .
see below
cort02-ipv6(config-if)#exit
cort02-ipv6(config)#Interface GigabitEthernet1/0/0
cort02-ipv6(config-if)#$monitor NET-ANALYSIS-INGRESS input
cort02-ipv6(config-if)#$monitor NET-ANALYSIS-EGRESS output
cort02-ipv6(config)#Interface GigabitEthernet1/0/4
cort02-ipv6(config)#Interface GigabitEthernet1/0/5
cort02-ipv6(config)#do sh flow interface
can you post show run (removing any confidential information)
BB
