Interface not displaying when I upgraded my ISR4331.
Zee-Far-Man
Hello Pros,
Today I upgraded my ISR4331 Router to IOS Version: ISR4300-Universal k9.17.06.07.SPA.bin. The upgraded was successful.  There was no Serial interface S0/1/0, Which was connected to Secure Circuit before.
I used command: Show Ip int br.
                          Show interface.
Interface did not shown.  I revered back to previous IOS, reload and Interface S0/1/0 appeared/shown as normal.
any idea what I was missing? Is this a common issue/problem?  Has Cisco fix this problem.  Need your Expert advice.
Thanks in advanced.
Zee-Far-Man
Giuseppe Larosa
Hello @Zee-Far-Man ,
with the old IOS XE version running check
show controller serial 0/1/0
and
show inventory
to understand the hardware module the serial port is part of.
Then in the release notes of the new IOS XE version ISR4300-Universal k9.17.06.07.SPA.bin you need to check for supported HW modules to see if that module is supported or not.
IF it is not supported it is a known issue and you should stay with the old version , if it is listed as supported you are likely hitting a SW bug on the new version.
Hope to help
Giuseppe
6 Replies 6
Do show interface serial
After upgrading do you see the interface?
MHM
Nope, Serial interface S0/1/0 did not show.
Ok
Interface serials  x/x
Can yoh add ip or description to serial interface?
If yes then is bug in new ios done show serial interface but you can config it
MHM
As I said there was not Serial interface, beside other interfaces.
Giuseppe Larosa
and
show inventory
Hope to help
Giuseppe
Thanks for your time and assistance. We will open TAC and ask if there is work around how to fix this issue.
Thanks again.
