Interface Output drops are higher than the actual output packets
dvag-nsafe
Hi again!
I have many stacks of 3850-12X48U-L Switches with SW 03.07.04E.
I discovered many Ports that show a higher error rate than they actually receive packets:
switch#sh int GigabitEthernet1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 00a2.8999.e001 (bia 00a2.8999.e001)
  Description: DATA-1074 - VOIP-1170 & DOT1X
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 1d21h
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 4294932290
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  5 minute input rate 105000 bits/sec, 92 packets/sec
  5 minute output rate 1427000 bits/sec, 155 packets/sec
     11247119 packets input, 10227303569 bytes, 0 no buffer
     Received 20586 broadcasts (16452 multicasts)
     0 watchdog, 16452 multicast, 0 pause input
     9343507 packets output, 11035540313 bytes, 0 underruns
     4294932290 output errors, 0 collisions, 0 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
I found BugID CSCuw50024, which is for the same hardware platform but not the IOS i'm using. It's for 15.2(3)E. Could it still be the same cosmetic issue?
Please advice...thanks!
0 Replies 0
