interface problem in cisco 2600
nmbhatia1333
I have lease line 2 Mbps terminated on my serial interface with ip unnumbered command
my fast ethernet has real valid ip which is being used by serial interface and this fast ethernet is connected to pix firewall and once in a day my data tx stops i have to shut and no shut this fast interface of the router thn the data transfer starts pls suggest what shoudl be done
the details of ceretian commands are as follows
ITPC#sh int fastEthernet 0/1
FastEthernet0/1 is up, line protocol is up
Hardware is AmdFE, address is 000d.bddb.127f (bia 000d.bddb.127f)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Half-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:51, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 7000 bits/sec, 4 packets/sec
5 minute output rate 7000 bits/sec, 4 packets/sec
103834 packets input, 23611633 bytes
Received 1 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 1 ignored
0 watchdog
125376 packets output, 75731111 bytes, 0 underruns
0 output errors, 65 collisions, 42 interface resets
0 babbles, 43 late collision, 59 deferred
45 lost carrier, 0 no carrier
ITPC#
ITPC# sh interfaces serial 0/1
Serial0/1 is up, line protocol is up
Hardware is PowerQUICC Serial
Interface is unnumbered. Using address of FastEthernet0/1
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input 00:00:03, output 00:00:00, output hang never
5 minute input rate 6000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
132436 packets input, 77841009 bytes, 0 no buffer
Received 7120 broadcasts, 0 runts, 0 giants, 0 throttles
328 input errors, 180 CRC, 127 frame, 0 overrun, 0 ignored, 21 abort
119829 packets output, 25790727 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
6 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=
spremkumar
Level 9
Level 9
hi
is there any specific reason behind placing your fastethernet in half duplex mode ?
is it possible for you to change that to full on both the router and pix side and observe for any probs ?
Also do a clear counter on your fastethernet interface and check out for any interface resets,errors or collisions after changing that to full duplex..
regds
Hi spremkumar
Thanks a lot for the help i have kept the interface in duplex auto mode and on pix it is "interface ethernet 0 100 full "after negotitation it is automatically coming to half dulpex i will keep both the router and pix interface to full dulpex and then observe
Regrds
N M Bhatia
SA,ITPC,BSNL
