Interface Tracking in IP Base/K9 Image
praetoleiad
Hi all,
Is Interface Tracking and HSRP supported in IP Base Image/K9 IOS? Thanks.
Latchum Naidu
Yes, it will support.
Do the config like below...
interface FastEthernet0/1
standby use-bia scope interface
standby ip "IP"
standby priority 110
standby preempt
standby authentication "authentication"
standby track FastEthernet0/0 30
Naidu.
Thanks sir for the reply.
The WAN Port will be track. On the LAN interface is the HSRP config.
Yes, the given example config for the same scenario.
Naidu.
