interface under WS-X6748-GE-TX module unable to apply policy map
Marlon Malinao
i have a cat6509 that has the following module, im trying to apply my policy-map to int g1/3
#show module
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
  3    0  2 port adapter Enhanced FlexWAN        WS-X6582-2PA
  4    0  2 port adapter Enhanced FlexWAN        WS-X6582-2PA
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL
  6    2  IPSec VPN Accelerator                  WS-SVC-IPSEC-1
#sho ver
IOS (tm) s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 25-Sep-09 10:31 by ccai
Image text-base: 0x40101040, data-base: 0x42DDCD90
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.2) with 983008K/65536K bytes of memory.
Processor board ID SMG1006N86C
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
2 Enhanced FlexWAN controllers (16 Serial).
14 Virtual Ethernet/IEEE 802.3 interfaces
76 Gigabit Ethernet/IEEE 802.3 interfaces
16 Serial network interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
policy-map qos-to
  class qos-voice
    priority percent 18
  class qos-routing
    bandwidth percent 3
  class qos-interactive-video
    bandwidth percent 14
  class qos-streaming-video
    bandwidth percent 10
  class qos-buscrit
    random-detect dscp-based
  class qos-callcontrol
    bandwidth percent 6
  class qos-netmgmt
    bandwidth percent 2
  class qos-transactional
    bandwidth percent 7
  class qos-bulkdata
    bandwidth percent 4
  class qos-scavenger
    bandwidth percent 1
  class class-default
    bandwidth percent 25
policy-map shape-wan-to
  class class-default
    shape average 100000000
   service-policy qos-to
interface GigabitEthernet1/3
description 100 MB link
mtu 1600
bandwidth 100000
no ip address
speed 100
duplex full
wrr-queue cos-map 1 1 1
wrr-queue cos-map 2 1 0
wrr-queue cos-map 3 1 2
wrr-queue cos-map 3 2 3
wrr-queue cos-map 3 3 6
wrr-queue cos-map 3 4 7
priority-queue cos-map 1 4 5
mls qos trust dscp
arp timeout 900
crypto connect vlan 113
max-reserved-bandwidth 100
error
(config-if)#service-policy output shape-wan-to-rhkd118-bra01-7206
shape average command is not supported in output direction for this interface
any idea, does the module really doesnt support MQC?
rgds,
mcmalinao
Giuseppe Larosa
Hello Mcmalinao,
a WS 6748 is a LAN linecard and does not support modular QoS that is supported for example on the flexwan modules.
see
QoS in C6500 configuration guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html
you can have policing and outbound queueing but no shaping
Hope to help
Giuseppe
Thanks!! Guislar!
