Interface Virtual-Access 1
What is an Interface Virtual-Access1? I recently noticed this interface on a 2800 series router after installing a second T1 circuit and creating a Multilink combining both my T1s. I hadn't noticed this interface before. What is its purpose?
paolo bevilacqua
Comes up cloned from you multilink interface other template. This because you can have multiple VA instances from a same template.
Peter Paluch
A Virtual-Access interface is an interface that is cloned (instantiated) from another interface, usually a Virtual-Template or Dialer. The relation between an Virtual-Template or Dialer interface and a Virtual-Access is quite similar to a difference between a class and the object in the object programming paradigm. The Dialer or Virtual-Template interfaces represent a template for creation of individual virtual interfaces. However, these are only templates. Whenever the template should start working as a real interface, it is instantiated into a Virtual-Access interface that is the actual live virtual interface through which packets are processed and routed.
You cannot configure the Virtual-Access interfaces directly. They are not really visible in your configuration and they are created and deleted on the fly. If you need to change the Virtual-Access settings, you always need to change the settings on the template interface from which the Virtual-Access has been cloned. The "show interfaces" will tell you what interface was used as a template for creating the particular Virtual-Access interface.
Best regards,
Peter
Thanks Peter,
Your explanation was very helpful.
virtual-template and virtual-access are created at the same time.
virtual-template is function as the interface.
here is my 1 cent...
interface Serial1/0
no ip address
encapsulation frame-relay
shutdown
serial restart-delay 0
frame-relay interface-dlci 103 ppp Virtual-Template1
no clns route-cache
end
r1#sh ip int brief
FastEthernet0/0 unassigned YES unset administratively down down
Serial1/0 unassigned YES unset administratively down down
Serial1/1 unassigned YES unset administratively down down
Serial1/2 unassigned YES unset administratively down down
Serial1/3 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES TFTP down down
Virtual-Template1 unassigned YES TFTP down down
Loopback0 unassigned YES unset up up
r1#
r1
