interfaces allocations?
alsayed
Hello Guys
let say am using IPS 4240,and i have servers on DMZ,here is it possible to allocates sensors ,1 on  inside,and 1 on outside and 1 DMZ  and C&C let say on inside..pls advise
6 Replies 6
Reza Sharifi
Hello alsayed,
IPS/IDS in mostly deployed on the outside perimeter devices and inside of perimeter devices.
Here is a document on understanding IDS/IPS for Defense in Depth:
http://www.sans.org/reading_room/whitepapers/detection/understanding_ips_and_ids_using_ips_and_ids_together_for_defense_in_depth_1381?show=1381.php&cat=detection
Reza
Hello riza
what about the sensing in DMZ?i have i-banking server in the dmz,,do i need to iniate a sensing  in DMZ?pls explain
I think if you protect the outside before even getting to DMZ is good enough.  You could add another device in your DMZ, but do you have enough man power to monitor all the devices and go through their logs? Putting a device is not so much of issue, but management and monitoring is.
I have seen when there is too much logs to look at, they don't get look at at all.
Reza
hello Riza
as a conclusion,i ll out 1 sensore on the outside and 1 sensor in inside and the c&c also in inside,and the IPS run in inline mode
Pls advise
Yes, in addition you can also use host based IDS on your end users workstations.
Reza
Thanks for ur Time Freind
