Intermittent Loss of Internet - How to Troubleshoot?
mnestander
Our school has a fairly simple setup. Most department switches (all cisco) are connected via fiber to our core switches. The core is connected to our router, which is connected to our ISP's router.
Every morning our Internet connection comes to a crawl for a varying amount of time. Internal services are not affected (shares, email etc).
When the bell rings for next period, everything returns to normal. This leads me to believe that perhaps a student is plugged in somewhere causing problems (intentionally or not). We don't have any set polices that disallow students from plugging in laptops, etc (which we will soon be addressing).
Anyway, my problem is how do I go about troubleshooting this problem? I have a machine running Wireshark in promiscuous mode, but I'm unsure how to analyze the results. Is this a job for something like Snort? Are there some commands on the router or core switches that I could be running to give me some clues?
I realize locking down ethernet ports, tighter network polices, etc would help, but I'm trying to learn something about network troubleshooting.
Some other info:
My ISP tells me they see nothing suspicious and that my bandwidth utilization across their line is normally below average
My CPU and bandwidth utilization on all my switches and my router are LOW
I can PING any of the websites I'm trying to reach just fine (at least those that allow ICMP)
None of my interfaces are registering a large number of errors (CRC, collisions, etc)
There are no outgoing ACLs
None of our DNS servers (responsible for outside and inside lookups) seem to be having any issues
Outgoing connections are NAT'ed, we have a few internal web servers and an Exchange server
14 Replies 14
vijayasankar
Level 4
Level 4
Hi Mark,
Would it be possible for you to provide a simple network/topology diagram depicting the links and ip addreses( including the details of your internet access setup, where nat is configured..etc.)
Are you having PAT (overload NAT) configured for general internet browsing.
If so, you can check the NAT translation statisitics during the problematic time.( show ip nat translations)
What is capacity of your internet link.?
What is min/average/max utilisation of both incoming and outgoing traffic on that link during the problematic period.?
Remember for http traffic, the outgoing traffic from your network will be less, when compared to return traffic received from the website for the http request?
So you should watch out both the outbound and inbound link utilisation of that internet link.
How browing access is provided to the users..? Any proxy server kind of setup?
Please revert back to us with as much details as possible to further diagnose the issue.
-VJ
one more remark: check for drops on your router interfaces with "show interface".
It will show you input and output drops.
What also might help is nbar protocol discovery, which can be configured through "ip nbar protocol-discovery" on an interface. Reduce the load interval to 30 seconds and check the values during your "crawl time".
Regards, Martin
Thanks for your replies...
All student workstations connect to the Internet via a sideways proxy server (squid, dans guardian). However, the problem occurs on all workstations.
I did a #sho ip nat trans# during the problem, but am unsure how to use the info? I can tell you that it was ~200 lines long.
** sho int on my router **
GigabitEthernet0/0
Internet address is 192.168.254.254/16
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is T
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 22:23:54
Input queue: 0/75/3/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 142000 bits/sec, 67 packets/sec
5 minute output rate 472000 bits/sec, 67 packets/sec
4180958 packets input, 2204810418 bytes, 0 no buffer
Received 486642 broadcasts, 0 runts, 0 giants, 3 throttles
0 watchdog, 0 multicast, 0 pause input
4121684 packets output, 3616949559 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1
Internet address is *clipped*.164.46/28
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Full-duplex, 100Mb/s, media type is T
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 4/4 (allocated/max allocated)
Available Bandwidth 5000 kilobits/sec
5 minute input rate 474000 bits/sec, 68 packets/sec
5 minute output rate 112000 bits/sec, 62 packets/sec
4209955 packets input, 3640882477 bytes, 0 no buffer
Received 630 broadcasts, 0 runts, 0 giants, 0 throttles
3735834 packets output, 1913232861 bytes, 0 underruns
sho run
interface GigabitEthernet0/0
ip address 192.168.254.254 255.255.0.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip accounting access-violations
ip inspect SDM_LOW out
ip nat inside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address *clipped*.164.46 255.255.255.240
ip access-group 102 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
no mop enabled
service-policy output SDM-Pol-GigabitEthernet0/1
ip classless
ip route 0.0.0.0 0.0.0.0 *clipped*.164.33
ip nat inside source list 1 interface GigabitEthernet0/1 overload
*** end sho run ***
Hi Mark,
Thanks for reverting back.
Would be interested to see your acls too. ( acl 100, 102)
I could see that "ip accounting" is enabled on the interface ge0/0
IP Accounting is a cpu intensive process. You can turn it on when needed for troubleshooting and later disable it to save cpu cycles.
If Internet access for everyone is available only through the Proxy server, then you may have to focus on that server to examine the reason for slow browing issue.
For test purpose can you allow one workstation to have direct internet access, instead of proxy. Once you have this workstation with direct internet access,
by-passing the proxy server, you can check the performance from that workstation.
From your intial post, i could understand that, only internet access is crawling, whereas PING is going through fine. Hence i strongly feel that there might be some issue with your proxy servers.
As stated earlier, I would need that ACL 100 to check what is allowed from inside lan to outside.
I have seen in some instances, the SQUID proxy periodically rebuilds/invalidates its cache, during that time http browing via that proxy server will get a performance hit. Not sure if this is what happening in your setup.
As stated earlier, if you could check the performance of internet access from a internal host( after bypassing proxy for this host alone), you will be able to isolate whether the issue is only related to proxy server or oubound internet access in general.
Kindly Revert back with your observations.
Hope this helps.
-VJ
Ok, I may have been unclear. Not all of our machines exit via the squid proxy, just the student machines. All of our machines, proxy'ed or not, experience the slow-down.
Here are the acl's on our router (clipped for privacy):
Router#sho access-lists
Standard IP access list 1
10 permit 192.168.0.0, wildcard bits 0.0.255.255 (1232783)
Extended IP access list 100
10 deny ip **.164.32 0.0.0.15 any (1899591)
20 deny ip host 255.255.255.255 any
30 deny ip 127.0.0.0 0.255.255.255 any
40 permit ip any any (37876428)
Extended IP access list 101
10 permit udp any host **.164.39
20 permit tcp any host **.164.39
30 permit udp any host **.164.38
40 permit tcp any host **.164.38
50 permit tcp host **.161.64 any
60 permit tcp host **.161.64 host **.164.46 eq 443
70 permit tcp host **.161.64 host **.164.46 eq 22
80 permit tcp host **.161.64 host **.164.46 eq cmd
90 permit tcp any host **.164.37 eq www
100 permit tcp any host **.164.35 eq 443
110 permit tcp any host **.164.35 eq www
120 permit tcp any host **.164.35 eq smtp
130 permit tcp any host **.164.34 eq www
140 deny ip 192.168.0.0 0.0.255.255 any
150 permit icmp any host **.164.46 echo-reply
160 permit icmp any host **.164.46 time-exceeded
170 permit icmp any host **.164.46 unreachable
180 deny ip 10.0.0.0 0.255.255.255 any
190 deny ip 172.16.0.0 0.15.255.255 any
200 deny ip 127.0.0.0 0.255.255.255 any
210 deny ip host 255.255.255.255 any
220 deny ip host 0.0.0.0 any
230 deny ip any any log
Extended IP access list 102
10 deny tcp host **.32.71 any (11113)
20 deny tcp host **.32.70 any (1016)
30 deny tcp host **.32.69 any (17584)
40 deny tcp host **.32.68 any (20633)
50 permit tcp any host **.164.34 eq www (2733833)
60 permit tcp any host **.164.42 eq www (3090)
70 permit tcp any host **.164.42 range 1417 1420 (6958)
80 permit udp any host **.164.42 range 1417 1420 (8)
90 permit tcp any host **.164.42 eq 407 (5077)
100 permit udp any host **.164.42 eq 407 (15)
110 permit tcp any host **.164.42 eq 443
120 permit tcp any host **.164.43 eq 3389 (20173)
130 permit tcp any host **.164.37 eq 3389 (9614)
140 permit tcp any host **.164.34 eq 3389 (6)
150 permit tcp any host **.164.37 eq www (937081)
160 permit tcp any host **.164.36 eq www (2058)
170 permit tcp any host **.164.45 range 5900 5901
180 permit tcp any host **.164.35 eq 443 (954183)
190 permit tcp any host **.164.35 eq smtp (714017)
200 permit tcp any host **.164.35 eq www (1663)
210 permit udp any host **.164.39 eq 5632
220 permit tcp any host **.164.39 eq 5631
230 permit udp any host **.164.38 eq 5632 (2)
240 permit tcp any host **.164.38 eq 5631 (71879)
250 permit udp any host **.164.41 eq 5632 (18)
260 permit tcp any host **.164.41 eq 5631 (141015)
270 permit udp any host **.164.40 eq 60554
280 permit tcp any host **.164.40 eq 60554
290 deny ip 192.168.0.0 0.0.255.255 any (10)
300 permit icmp any host **.164.46 echo-reply
310 permit icmp any host **.164.46 time-exceeded (1031061)
320 permit icmp any host **.164.46 unreachable (9984)
330 permit tcp host **.161.64 host **.164.46 eq 443
340 permit tcp host **.161.64 host **.164.46 eq 22
350 permit tcp host **.161.64 host **.164.46 eq cmd
360 deny ip 10.0.0.0 0.255.255.255 any (84)
370 deny ip 172.16.0.0 0.15.255.255 any (3)
380 deny ip 127.0.0.0 0.255.255.255 any
390 deny ip host 255.255.255.255 any
400 deny ip host 0.0.0.0 any
410 deny ip any any log (374627)
Extended IP access list **name clipped**
10 permit tcp any any eq 8200
20 permit tcp any any eq 443
Thanks!
hello,
This can also be due to the class-based QOS configured on your interface.. can you post us that config too ?? are you giving any priorities to any other traffic other than HTTP ? what all protocols flow in your network , through internet ? You can also remove the service policy command and just run http service, to isolate the issue !!!
Raj
Incoming traffic:
http (webservers)
https (exchange OWA)
smtp (exchange)
Out:
websurfing (http, https, streaming audio, etc)
ftp
I'm not sure what you mean by "remove the service policy"
As for QOS, I think this is what you are referring to (???)
Router#sho class-map
Class Map match-any SDMSignal-GigabitEthernet0/1 (id 1)
Match protocol h323
Match protocol rtcp
Class Map match-any SDMRout-GigabitEthernet0/1 (id 6)
Match protocol bgp
Match protocol egp
Match protocol eigrp
Match protocol ospf
Match protocol rip
Match protocol rsvp
Class Map match-any SDMBulk-GigabitEthernet0/1 (id 2)
Match protocol exchange
Match protocol ftp
Match protocol irc
Match protocol nntp
Match protocol pop3
Match protocol printer
Match protocol secure-ftp
Match protocol secure-irc
Match protocol secure-nntp
Match protocol secure-pop3
Match protocol smtp
Match protocol tftp
Class Map match-any SDMManage-GigabitEthernet0/1 (id 8)
Match protocol dhcp
Match protocol dns
Match protocol imap
Match protocol kerberos
Match protocol ldap
Match protocol secure-imap
Match protocol secure-ldap
Match protocol snmp
Match protocol socks
Match protocol syslog
Class Map match-any SDMIVideo-GigabitEthernet0/1 (id 3)
Match protocol rtp video
Class Map match-any class-default (id 0)
Match any
Class Map match-any SDMSVideo-GigabitEthernet0/1 (id 9)
Match protocol cuseeme
Match protocol netshow
Match protocol rtsp
Match protocol streamwork
Match protocol vdolive
Class Map match-any SDMTrans-GigabitEthernet0/1 (id 7)
Match protocol citrix
Match protocol finger
Match protocol notes
Match protocol novadigm
Match protocol pcanywhere
Match protocol secure-telnet
Match protocol sqlnet
Match protocol sqlserver
Match protocol ssh
Match protocol telnet
Match protocol xwindows
Class Map match-any SDMVoice-GigabitEthernet0/1 (id 5)
Match protocol rtp audio
Class Map match-any SDMScave-GigabitEthernet0/1 (id 4)
Match protocol napster
Match protocol fasttrack
Match protocol gnutella
policy-map SDM-Pol-GigabitEthernet0/1
class SDMVoice-GigabitEthernet0/1
priority percent 70
set dscp ef
class SDMManage-GigabitEthernet0/1
bandwidth remaining percent 3
set dscp cs2
class SDMTrans-GigabitEthernet0/1
bandwidth remaining percent 33
set dscp af21
class SDMRout-GigabitEthernet0/1
set dscp cs6
class SDMSignal-GigabitEthernet0/1
bandwidth remaining percent 40
set dscp cs3
Thanks again
Not sure if this is relevant, but I noticed the DROPS:
Router#sho int g0/1 switching
GigabitEthernet0/1 $FW_OUTSIDE$$ETH-WAN$
Throttle count 78
Drops RP 323 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 1021562 Drops 0
Protocol IP
Switching path Pkts In Chars In Pkts Out Chars Out
Process 4023090 1323166173 3987250 305176872
Cache misses 1 - - -
Fast 63086484 3162115666 49777734 1082941822
Auton/SSE 0 0 0 0
Protocol ARP
Process 11803 708180 962 57720
Cache misses 0 - - -
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 0 0 119200 7152000
Fast 0 0 0 0
Auton/SSE 0 0 0 0
NOTE: all counts are cumulative and reset only after a reload.
Router#sho int g0/1 switchport ?
| Output modifiers
% Gi0/1 is not a switchable port
Router#sho int g0/0 switching
GigabitEthernet0/0 $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$FW_INSIDE$$ETH-LAN$
Throttle count 375
Drops RP 5993 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 3967308 Drops 2
Protocol IP
Process 4992099 656598230 2978590 1117785666
Fast 49909339 1202096437 62845107 3042327746
Auton/SSE 0 0 0 0
Protocol ARP
Process 4003643 240590776 1281527 76891620
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 3117710 3652788604 119203 7152180
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Router#
What is the capacity of your connection to your upstream provider? You may be hitting the ceiling during the peak times and seeing that you have proxy server(s), they may have significant impact on your total capacity, depending on prefetch options, etc.
Chris
Thanks for your reply - as I mentioned, our ISP has noticed no capacity thresholds being met at any time.
One thing I'm wondering about - Could the fact that our ACLs being applied to returning traffic be part of the problem? For example, the log shows several packets from outside port 80 to inside being blocked.
ACL's are exact. They either do or don't work. You have a pattern that points to a slowdown of some resource on your network (seeing that it's not bandwidth related).
Do a 'show proc cpu' during the slowdown period and compare with the same for normal period and let us know what the CPU load is like. Also, what platform is your core router?
Here is an example of my log - there are tons of these from various IP addresses all from port 80 (as though it is returning traffic from sites surfed to from within our school)
1/30/2007 9:37 Local7.Info 192.168.254.254 304191: 304199: *Jan 30 16:41:57.879 UTC: %SEC-6-IPACCESSLOGP: list 102 denied tcp 17.250.248.77(80) -> ***.***.164.46(49177), 4 packets
***.***.164.46 is the public side of router g0/1
I totally agree with the fact that ACLs are exact, it's so strange that we would be able to surf at all if port 80 coming back in is denied.
Our platform: Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(3d)
Hope that's what you meant.
Yes, that's what I wanted to see. Also, please provide the output from 'show proc cpu'
Chris
I was going to post the sho proc cpu, but everything is < 1% for each time interval. In fact, most of them are at 0.00. The only one that changes much is IP Input with a 5 minute interval of ~0.55
thanks
