10-24-2018 05:55 PM
Hi To All,
I have issue on my Cisco Router ISR4221/K9 with iOS 16.08.1.
On my LibreNMS Monitoring the router is monitored down because SNMP is unreachable.
Upon checking on the logs of the router this "SNMP-3-RESPONSE_DELAYED: processing GetNext of ciscoMgmt.810.1.2.1.1 (24012 msecs)" is on the log list.
10-25-2018 07:00 AM
This looks to be a bug in IOS 16.08.1. Bug ID is CSCvm07355.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvm07355
10-25-2018 04:59 PM
Hi Spooster,
Thank you for this, i will check the bug details and give you feedback.
10-25-2018 11:19 AM
SNMP by default has low priority, so in case of e.g. high CPU utilization, SNMP traffic could be delayed or dropped.
Try and configure:
Switch(config)#snmp-server ip precedence 7
Or as an alternative increase the snmpwalk timeout on your LibreNMS management system...
10-25-2018 05:00 PM
Hi Georg
Thank you for this, i will try also this suggestion and observe what will happen.
