internet bandwidth sharing for every user in our company
thomas.luxl
how can I configure a Catalyst 3750, which interface is patched on the ISP router
(internet uplink bandwidth = 20Mbps with)
to allow all active users are sharing the bandwidth (either 5, 50, 100, user simultaneously ... in internet surfing. right now it's like when a user starts a larger download that it uses the bulk of the bandwidth, and other users can reach all remaining extremely slow access times. thanks for your support!
tom
Marwan ALshawi
if you are using a switch as a edge device with the ISP no a router your options are limited
what you can do is to match certain type of traffic onm th einput interfaces and police this traffic to a certain amount of bandwidth for example match FTP if its more than 5 Mbp then start droping the extra trafftic
wish this help
if helpful Rate
hi marwanshawi,
first of all...thanks for your quick respond. mainly it is www-traffic. no chance with qos or bandwidth sharing on catalyst 3750? maybe I have more possibilty do do it on ASA5520?
thomas
Joseph W. Doherty
The      Author of this posting offers the information contained within this      posting without consideration and with the reader's understanding   that    there's no implied or expressed suitability or fitness for any    purpose.   Information provided is for informational purposes only  and   should not   be construed as rendering professional advice of any  kind.   Usage of  this  posting's information is solely at reader's own  risk.
Liability Disclaimer
In      no event shall Author be liable for any damages whatsoever    (including,   without limitation, damages for loss of use, data or    profit) arising  out  of the use or inability to use the posting's    information even if  Author  has been advised of the possibility of  such   damage.
Posting
Practically impossible to regulate inbound bandwidth to insure quality, even when severely capping various traffic type's allowable bandwidth.  You need to be able to manage the congestion point's egress.  So, for example, when you note problem occurs when someone starts a larger download, you would need to manage the ISP side of the link.
Assuming you can manage the egress bottleneck, most L3 switches QoS features often make it difficult do such congestion management really well.  For 20 Mbps, would recommend a small router with base IOS feature set to manage the congestion.  Again, though, the ISP side could be an issue.
