Internet not reaching Core/Access Switch
maisiba
Router has internet but Core Switch not picking, what i'm i missing?
Router and Switch can ping each other
Router Configs
Router#sh run
Building configuration...
Current configuration : 2966 bytes
! Last configuration change at 06:51:08 UTC Fri Nov 26 2021
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$De./$aFvTeKMWxh6GZbBORCt/I.
no aaa new-model
ip name-server 8.8.8.8
ip domain name xxxxx
subscriber templating
license udi pid ISR4331/K9 sn FDO2434015D
diagnostic bootup level minimal
username xxxxxx secret 5 $1$Wt2e$OQBtmvjwMxVtdmfGHSWoi/
username yyyyyy secret 5 $1$qM3u$KeoRpdz.GQkdUDnrajzrz/
redundancy
mode none
interface GigabitEthernet0/0/0
description WAN
ip address xx.xx.244.126 255.255.255.254
ip nat outside
negotiation auto
ip virtual-reassembly
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
no ip address
ip nat inside
negotiation auto
interface GigabitEthernet0/0/2.200
description LAN
encapsulation dot1Q 200
ip address 172.30.235.1 255.255.255.0
ip nat inside
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
router eigrp 1
network 0.0.0.0
network 10.64.101.0 0.0.0.255
network 172.30.235.0 0.0.0.255
ip nat inside source list 101 interface GigabitEthernet0/0/2 overload
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 xx.xx.244.127 10
ip ssh version 2
access-list 101 permit ip 192.168.235.0 0.0.0.255 any
access-list 101 permit ip 10.64.101.0 0.0.0.255 any
access-list 101 permit ip 172.22.171.0 0.0.0.255 any
access-list 101 permit ip 172.30.235.0 0.0.0.255 any
control-plane
line con 0
login local
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
Router#
Core Switch Configs
CORE_SWITCH#sh run
% VRF table-id 0 not active
Current configuration : 3708 bytes
version 15.1
no service pad
service compress-config
hostname CORE_SWITCH
boot-start-marker
boot system flash bootflash:cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
username xxxxx secret 5 $1$Wt2e$OQBtmvjwMxVtdmfGHSWoi/
no aaa new-model
hw-module uplink select tengigabitethernet
ip vrf mgmtVrf
ip dhcp excluded-address 10.64.101.1 10.64.101.10
ip dhcp excluded-address 172.22.171.1 172.22.171.10
ip dhcp excluded-address 10.64.101.240 10.64.101.254
ip dhcp excluded-address 172.22.171.240 172.22.171.254
ip dhcp excluded-address 192.168.235.1 192.168.235.10
ip dhcp pool grnd_FLR_DATA
network 10.64.101.0 255.255.255.0
default-router 10.64.101.1
dns-server 8.8.8.8 8.8.4.4
lease 7
ip dhcp pool GRND_FLR_VOICE
network 172.22.171.0 255.255.255.0
default-router 172.22.171.1
option 150 ip 10.66.112.2 10.66.112.3
dns-server 8.8.8.8 4.2.2.2
lease 7
ip dhcp pool cctv
network 192.168.235.0 255.255.255.0
default-router 192.168.235.1
dns-server 10.66.112.10 196.201.225.19 196.201.225.18
lease 7
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
redundancy
mode sso
vlan internal allocation policy ascending
vlan 10
name VOICE
vlan 100
name AUDIO_VISUAL
vlan 110
name DATA
vlan 120
name SERVERS
vlan 128
name CCTV
vlan 200
name managemnt
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface TenGigabitEthernet1/1
switchport mode trunk
switchport nonegotiate
interface TenGigabitEthernet1/2
interface TenGigabitEthernet1/3
interface TenGigabitEthernet1/4
interface TenGigabitEthernet1/5
interface TenGigabitEthernet1/6
interface TenGigabitEthernet1/7
interface TenGigabitEthernet1/8
interface TenGigabitEthernet1/9
interface TenGigabitEthernet1/10
interface TenGigabitEthernet1/11
interface TenGigabitEthernet1/12
interface TenGigabitEthernet3/1
interface TenGigabitEthernet3/2
interface GigabitEthernet3/3
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface Vlan1
no ip address
interface Vlan10
description voice
ip address 172.22.171.1 255.255.255.0
interface Vlan110
description data
ip address 10.64.101.1 255.255.255.0
interface Vlan128
ip address 192.168.235.1 255.255.255.0
interface Vlan200
ip address 172.30.235.2 255.255.255.0
router eigrp 1
network 0.0.0.0
eigrp stub connected summary
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.30.235.1
line con 0
stopbits 1
line vty 0 4
password (&%^09234bhbgc!#@132ih
login
end
CORE_SWITCH#
Switch ping from Router
Router#ping 172.30.235.2
Sending 5, 100-byte ICMP Echos to 172.30.235.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Router ping from Switch
CORE_SWITCH#ping 172.30.235.1
Sending 5, 100-byte ICMP Echos to 172.30.235.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Internet ping from Router
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/36/54 ms
Internet ping from Switch
CORE_SWITCH#ping 8.8.8.8
Success rate is 0 percent (0/5)
Internet Tracert from Switch
CORE_SWITCH#traceroute 8.8.8.8
Tracing the route to 8.8.8.8
VRF info: (vrf in name/id, vrf out name/id)
1 172.30.235.1 0 msec 0 msec 0 msec
2 * * *
3 * * *
4 * * *
5 * * *
not sure if this is a typo ?
--> ip nat inside source list 101 interface GigabitEthernet0/0/2 overload
According to your configuration, the WAN interface is GigabitEthernet0/0/0. Make sure that is reflected in your config:
--> ip nat inside source list 101 interface GigabitEthernet0/0/0 overload
16 Replies 16
Ooh yes, thanks, that was a typo.
Corrected but still internet unreachable from Core Switch
do the clients connected to the core switch get an Internet connection ?
Try to ping from the switch with a source ip:
CORE_SWITCH#ping 8.8.8.8 source 172.30.235.2
CORE_SWITCH#ping 8.8.8.8 so 172.30.235.2
Packet sent with a source address of 172.30.235.2
post the output of 'show ip route' from both the switch and the router...
Router#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is xx.159.244.127 to network 0.0.0.0
S* 0.0.0.0/0 [10/0] via xx.159.244.127
10.0.0.0/24 is subnetted, 1 subnets
D 10.64.101.0
[90/3072] via 172.30.235.2, 02:34:30, GigabitEthernet0/0/2.200
154.159.0.0/16 is variably subnetted, 2 subnets, 2 masks
C xx.159.244.126/31 is directly connected, GigabitEthernet0/0/0
L xx.159.244.126/32 is directly connected, GigabitEthernet0/0/0
172.22.0.0/24 is subnetted, 1 subnets
D 172.22.171.0
172.30.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.30.235.0/24 is directly connected, GigabitEthernet0/0/2.200
L 172.30.235.1/32 is directly connected, GigabitEthernet0/0/2.200
D 192.168.235.0/24
CORE_SWITCH#sh ip route
Gateway of last resort is 172.30.235.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 172.30.235.1
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.64.101.0/24 is directly connected, Vlan110
L 10.64.101.1/32 is directly connected, Vlan110
xx.159.0.0/31 is subnetted, 1 subnets
D xx.159.244.126 [90/28416] via 172.30.235.1, 02:38:27, Vlan200
172.22.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.22.171.0/24 is directly connected, Vlan10
L 172.22.171.1/32 is directly connected, Vlan10
C 172.30.235.0/24 is directly connected, Vlan200
L 172.30.235.2/32 is directly connected, Vlan200
192.168.235.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.235.0/24 is directly connected, Vlan128
L 192.168.235.1/32 is directly connected, Vlan128
Hello
You have no NAT assigned to the routed port of the lan interface, Also change the switchport from a trunk to an access port in vlan 200 then test again
Router
description LAN
ip nat inside
switch
default interface GigabitEthernetx/x
description RTR facing
switchport host
switchport access vlan 200
Kind Regards
Paul
Router WAN interface has NAT assigned, please re-check the configs above.
Made below changes on switch, still internet unreachable from switch.
switchport mode access
spanning-tree portfast
when you ping 8.8.8.8 from 172.30.235.2 (the switch) and then issue the command 'show ip nat translation *" on the router, do you actually see an entry for 172.30.235.2 ?
Hello Georg,
No, there is no translation recorded on router as shown below;
CORE_SWITCH#exit
[Connection to 172.30.235.2 closed by foreign host]
Router#sh ip nat translations
Total number of translations: 0
Hello
Apologies missed that...
TBH your configuration looks okay, apart from the dynamic PAT statement pointing to gig0/0/2 but you say that has been removed and replaced to point to gig0/0/0 - correct?
What rtr are you using and version of software?
rtr
sh version
Kind Regards
Paul
Hello Paul,
Yes corrections were done and dynamic pat points to g0/0/0 and still switch not able to ping 8.8.8.8.
I'm using Cisco 4331, below sh ver
Router#sh ver
Cisco IOS XE Software, Version 16.06.04
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sun 08-Jul-18 04:33 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 14 hours, 19 minutes
Uptime for this control processor is 14 hours, 21 minutes
System returned to ROM by PowerOn
System image file is "bootflash:isr4300-universalk9.16.06.04.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1795999K/6147K bytes of memory.
Processor board ID FDO2435M0HB
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
Hello
Can you try the following:
no access-list extended 101
access-list 101 deny host xx.xx.244.126 any < deny the wan interface from the nat acl
router eigrp 1
no network 0.0.0.0
no network 10.64.101.0 0.0.0.255 < I dont see this on any physical interface
Kind Regards
Paul
Hello Paul,
Apparently, the router had no ACLs, dunno how they disapeared.
Added them back and Core Switch picked internet
ACLs added
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/28/36 ms
Thank you very much all!
