Internet not reaching Core/Access Switch
maisiba
Router has internet but Core Switch not picking, what i'm i missing?
Router and Switch can ping each other
Router Configs
Router#sh run
Building configuration...
Current configuration : 2966 bytes
! Last configuration change at 06:51:08 UTC Fri Nov 26 2021
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$De./$aFvTeKMWxh6GZbBORCt/I.
no aaa new-model
ip name-server 8.8.8.8
ip domain name xxxxx
subscriber templating
license udi pid ISR4331/K9 sn FDO2434015D
diagnostic bootup level minimal
username xxxxxx secret 5 $1$Wt2e$OQBtmvjwMxVtdmfGHSWoi/
username yyyyyy secret 5 $1$qM3u$KeoRpdz.GQkdUDnrajzrz/
redundancy
mode none
interface GigabitEthernet0/0/0
description WAN
ip address xx.xx.244.126 255.255.255.254
ip nat outside
negotiation auto
ip virtual-reassembly
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
no ip address
ip nat inside
negotiation auto
interface GigabitEthernet0/0/2.200
description LAN
encapsulation dot1Q 200
ip address 172.30.235.1 255.255.255.0
ip nat inside
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
router eigrp 1
network 0.0.0.0
network 10.64.101.0 0.0.0.255
network 172.30.235.0 0.0.0.255
ip nat inside source list 101 interface GigabitEthernet0/0/2 overload
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 xx.xx.244.127 10
ip ssh version 2
access-list 101 permit ip 192.168.235.0 0.0.0.255 any
access-list 101 permit ip 10.64.101.0 0.0.0.255 any
access-list 101 permit ip 172.22.171.0 0.0.0.255 any
access-list 101 permit ip 172.30.235.0 0.0.0.255 any
control-plane
line con 0
login local
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
Router#
Core Switch Configs
CORE_SWITCH#sh run
% VRF table-id 0 not active
Current configuration : 3708 bytes
version 15.1
no service pad
service compress-config
hostname CORE_SWITCH
boot-start-marker
boot system flash bootflash:cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
username xxxxx secret 5 $1$Wt2e$OQBtmvjwMxVtdmfGHSWoi/
no aaa new-model
hw-module uplink select tengigabitethernet
ip vrf mgmtVrf
ip dhcp excluded-address 10.64.101.1 10.64.101.10
ip dhcp excluded-address 172.22.171.1 172.22.171.10
ip dhcp excluded-address 10.64.101.240 10.64.101.254
ip dhcp excluded-address 172.22.171.240 172.22.171.254
ip dhcp excluded-address 192.168.235.1 192.168.235.10
ip dhcp pool grnd_FLR_DATA
network 10.64.101.0 255.255.255.0
default-router 10.64.101.1
dns-server 8.8.8.8 8.8.4.4
lease 7
ip dhcp pool GRND_FLR_VOICE
network 172.22.171.0 255.255.255.0
default-router 172.22.171.1
option 150 ip 10.66.112.2 10.66.112.3
dns-server 8.8.8.8 4.2.2.2
lease 7
ip dhcp pool cctv
network 192.168.235.0 255.255.255.0
default-router 192.168.235.1
dns-server 10.66.112.10 196.201.225.19 196.201.225.18
lease 7
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
redundancy
mode sso
vlan internal allocation policy ascending
vlan 10
name VOICE
vlan 100
name AUDIO_VISUAL
vlan 110
name DATA
vlan 120
name SERVERS
vlan 128
name CCTV
vlan 200
name managemnt
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface TenGigabitEthernet1/1
switchport mode trunk
switchport nonegotiate
interface TenGigabitEthernet1/2
interface TenGigabitEthernet1/3
interface TenGigabitEthernet1/4
interface TenGigabitEthernet1/5
interface TenGigabitEthernet1/6
interface TenGigabitEthernet1/7
interface TenGigabitEthernet1/8
interface TenGigabitEthernet1/9
interface TenGigabitEthernet1/10
interface TenGigabitEthernet1/11
interface TenGigabitEthernet1/12
interface TenGigabitEthernet3/1
interface TenGigabitEthernet3/2
interface GigabitEthernet3/3
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface Vlan1
no ip address
interface Vlan10
description voice
ip address 172.22.171.1 255.255.255.0
interface Vlan110
description data
ip address 10.64.101.1 255.255.255.0
interface Vlan128
ip address 192.168.235.1 255.255.255.0
interface Vlan200
ip address 172.30.235.2 255.255.255.0
router eigrp 1
network 0.0.0.0
eigrp stub connected summary
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.30.235.1
line con 0
stopbits 1
line vty 0 4
password (&%^09234bhbgc!#@132ih
login
end
CORE_SWITCH#
Switch ping from Router
Router#ping 172.30.235.2
Sending 5, 100-byte ICMP Echos to 172.30.235.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Router ping from Switch
CORE_SWITCH#ping 172.30.235.1
Sending 5, 100-byte ICMP Echos to 172.30.235.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Internet ping from Router
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/36/54 ms
Internet ping from Switch
CORE_SWITCH#ping 8.8.8.8
Success rate is 0 percent (0/5)
Internet Tracert from Switch
CORE_SWITCH#traceroute 8.8.8.8
Tracing the route to 8.8.8.8
VRF info: (vrf in name/id, vrf out name/id)
1 172.30.235.1 0 msec 0 msec 0 msec
2 * * *
3 * * *
4 * * *
5 * * *
16 Replies 16
Hello
Thanks for letting us know, As I stated your configuration looked correct and it was vexing me as to why it wasn’t working, in my last post I was pondering with he fact that as your rtr was running on ios-xe maybe we had to exclude the wan interface from the nat acl, however this wasn’t to be the case.
Kind Regards
Paul
Just out of curiosity, how did you resolve this ?
