internet router access-list
nataraj_v
Dear All,
we have a WAN network .. now each branch office is directly connected to Local ISP , from a new 3com router.. can any body pls tell me..
wht are the minimum access-lists needed to block possible things on the router.
thanks in advance.
Nataraj
7 Replies 7
arvindchari
Level 3
Level 3
Hi Nataraj
This is highly subjective and varies from site to site. You will need to determine why exactly your offices are connected i.e. file sharing or remote access to an sql server etc etc.
Determine the ports and protocols that are in use by those specific applications. Use extended access lists to particularly permit only those ip subnets and ports.
New applications will require you to modify the access list periodically.
This would provide the basic security you require.
Hope it works out!
example access list to permit http traffic
access-list 101 ip permit any any eq 80
this creates an access list named 101 which permits the ip protocol from any ip to any ip where the port number equals 80 (http).
Dont foget that there is an implicit deny at the end of each list! :)
Good luck!
balajitvk
Level 4
Level 4
Minimum access-list to protect a network depends upon your needs, which services you want to allow and block. But we can use this to protect from general virus attacks upto certail level.
ip access-list extended VIRUS_TRAFFIC_TO_DROP_etth
deny 53 any any
deny 55 any any
deny 77 any any
deny tcp any any eq ident
deny tcp any any eq 135
deny tcp any any range 137 139
deny tcp any any eq 445
deny tcp any any eq 1023
deny tcp any any eq 1025
deny tcp any any eq 1214
deny tcp any any eq 1433
deny tcp any any eq 1434
deny tcp any any eq 3127
deny tcp any any eq 1981
deny tcp any any eq 2745
deny tcp any any range 3127 3199
deny tcp any any eq 4444
deny tcp any any eq 4899
deny tcp any any eq 5000
deny tcp any any eq 5554
deny tcp any any eq 6129
deny tcp any any eq 9898
deny tcp any any eq 9996
deny udp any any eq 135
deny udp any any range netbios-ns netbios-ss
deny udp any any eq 445
deny udp any any eq 1023
deny udp any any eq 1433
deny udp any any eq 1434
deny udp any any range 3127 3199
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any source-quench
permit icmp any any time-exceeded
permit udp any eq bootpc any eq bootps
permit ip any any
if u r using this, ensure it don't affects any of your intented services.
tcordier
Hi Nataraj,
the best approach from a security point of view is to look at it from the other side: you should deny everything except the ports and IP addresses you really need to permit. You can check with your business and users what applications (IP addresses and ports) they need, and permit these, and deny the rest. If you have no or only an incomplete idea of what is needed, you can deny everything, and log what has been blocked, by using e.g.
access-list 1 deny any any log
as the last entry in your access list. Then you can check the router log and explicitly select those applications and flows which are needed. Again, your focus should not be on what to deny, but on what to permit.
HTH, Thomas
Dear All,
thank you very much for ur replies.
Now ill elobarte bit more my setup.
we have a wan network. now each location contains 2 routers. one router is connected to WAN and other is connected for internet ( local ISP) . already wan router configuered.
in this internet router .. only internet traffic goes nothing else. now pls guide me further.
as one of u suggested to block well known virus ports.in the same way i want to put anti spoofing rules also.
waiting for your replies.
Thanks in advance
nataraj
Hello Nataraj,
the minimum ports you need to have for Internet access are 80 (www), 443 (SSL), and 53 (domain, or dns, for name resolution). If you want to allow FTP access as well, you would also need to allow port 21.
In addition, you can configure ´ip verify unicast reverse-path´ on the interface connecting to the Internet, which basically is a security measure that checks the source IP address of packets received inbound on the interface to see if the interface is the interface that would normally be used by the router to route packets to the source IP.
So, putting this all together, your config would look like this:
ip cef
interface Serial0/0
ip access-group 101 in
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq www
access-list 101 permit udp any any eq domain
access-list 101 permit tcp any any eq ftp
Depending on the IOS version you are running, you could also configure Network-based application recognition (NBAR), and block certain URLs. Check if your router supports this configuration (this is from CCO and blocks code red):
Router(config)#class-map match-any http-hacks
Router(config-cmap)#match protocol http url "*.ida*"
Router(config-cmap)#match protocol http url "*cmd.exe*"
Router(config-cmap)#match protocol http url "*root.exe*"
Router(config-cmap)#match protocol http url "*readme.eml*"
Router(config)#policy-map mark-inbound-http-hacks
Router(config-pmap)#class http-hacks
Router(config-pmap-c)#set ip dscp 1
Router(config)#interface serial 0/0
Router(config-if)#service-policy input mark-inbound-http-hacks
Router(config)#access-list 101 deny ip any any dscp 1
So, including the code red block, your config would look like this:
ip cef
interface Serial0/0
class http-hacks
set ip dscp 1
I hope this doesn´t get too messy, but give it a try.
GP
thanks GP , along with this , if i want to implement anti spoofin rules .. wht are the access-lists for them..
im sorry , actually im a firewall admin and ids engineer.. didnt worked much on routers.. thts y im asking..
thanks in advance
regards
nataraj
Hello Nataraj,
for anti-spoofing, you would deny what are called private space addresses, in addition to the Microsoft Loopback address space of 169.254.0.0/16.
You can add this to your access list, the access list would then look like this:
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 169.254.0.0 0.0.255.255 any
HTH,
GP
