Internet router with NAT and control bandwidth limit
ssweehinlew
I would like to control the bandwidth limit from the router interface with policy map. But, it does not work. Below is the configuration. Please help me to take a look. I suspect it is due to the NAT setting cause the bandwidth limit does not work. If I remove the NAT, users with that subnet will not be able to access internet.
class-map match-all subnet-a
 match access-group 101
 policy-map physical
 class subnet-a
   police 1200000 8000000 conform-action transmit  exceed-action drop
interface FastEthernet0/0
 ip address 10.1.3.254 255.255.255.0
 ip nat inside
 speed auto
 full-duplex
 service-policy input physical
 service-policy output physical
interface FastEthernet0/1
 ip address 192.168.2.29 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
ip route 0.0.0.0 0.0.0.0 192.168.2.1 permanent
ip nat inside source list 101 interface FastEthernet0/1 overload
access-list 101 permit ip 10.1.3.0 0.0.0.255 any
Jose Jara
Level 3
Level 3
The inbound traffic - the traffic coming to the interface - will be policed as the class-map is matching traffic sourced from 10.1.3.X range. On the other hand, for the outbound traffic - the outgoing traffic from the interface - will not be policed as the class-map is matching traffic sourced from 10.1.3.X range and this is the destination instead the source.
So, for this to work you must create another class-map matching the traffic destined to 10.1.3.X, then create another policy-map and apply it to the interface with service-policy output. Another option would be to match all the traffic coming from interface Fa0/1 with match input-interface in the class-map and in this way you do not have to create another ACL.
Hope this helps,
Jose.
Jose Jara
Level 3
Level 3
Hope this helps,
Jose.
ssweehinlew
Thanks. It is working fine now.
